Radio Communications Logo
l
laura little Posted on Feb 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My baofeng bff8hp Cant hear anything not even announcement turning on,other party can hear my transmit got this replacement unit because last unit had same tbl. Could it be the battery,only got unit.
sadiq muhammad
Level 2:
Champion:
  • Radio Commun... Expert 228 Answers
  • Posted on Feb 22, 2019
sadiq muhammad
Level 2:
Champion:
Answers
228
Questions
0
Helped
81096
Points
438
Your speaker is not working, change the speaker 16 ohms, 1watt.
5 Related Answers
A
Anonymous
  • Posted on Jul 06, 2007
SOURCE: cant hear anything
try to dismantle your phone...re-align flex cable/ribbon of your unit.
Anonymous
  • 90 Answers
  • Posted on Jul 20, 2008
SOURCE: transmits but doesnt receive
If the meter shows that it's receiving something, the microphone may be the problem. Another possibility is the speaker & plugging an external speaker in would confirm this. Aslo make sure the squelch control is turned all the way to the left (counter-clockwise) & the RF gain is turned to the right (clockwise).
Anonymous
  • 379 Answers
  • Posted on Dec 24, 2008
SOURCE: headset failed to transmit
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.happened to me a lot . hs850
Norm Pearl
  • 108 Answers
  • Posted on Sep 14, 2012
SOURCE: I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
richdean9572
Richard Dean
  • 3 Answers
  • Posted on Oct 16, 2013
SOURCE: My baofeng uv-5r will not transmit any solutions?
Don't know what software you used but try looking up a program called Chirp on the internet and use it to progran the radio. The program gets updated a lot. It has worked well for a large group of us. Is the battery fully charged?
Can the Baofeng work the 6 meter Ham Band
Normally baofeng transreceivers are working on 2 meter band(144...mhz)and uhf band.You can check it with instruction manual if it covers the 50 mhz range?.I also have baofeng which can receive 65 mhz to 108 mhz(fm band)but I cant transmit.
I bought a baofeng uv5r and want to link it to my work radio which is a vertex standard vx160u..I can transmit from the work radio to the baofeng but cant figure out how to transmit back to the vertex
First of all, technically, you can't use this radio to talk to anyone other than ham radio- that being said, if you want to proceed at your own risk. Ok, is your work radio an analog radio? Is it narrowband FM? Is it digital MOTOTRBO? Last two will make if difficult. Digital is impossible. Next, find out the exact transmit and receive frequencies for your radio. They may not be both the same if you have a radio 'repeater' your input frequency could be 5MHz higher than your receive frequency. And last- you need to know if your system has a "PL" tone (CTCSS, or DCS) subaudible tone that will break the squelch. So there are several variables that you will need your plant supervisor to relay to you. Good luck. You can probably get much of this info on line from radio reference.
2answers
I need to tune my baofeng gt-3 mk2 to the same frequency as my baofeng bf-888s I can hear the bf-888s with my gt-3 but cannot talk I've tried every website why cant i talk over it????
1. Make sure both radios are transmitting and receiving on the same frequency (no repeater offset).
2. Either turn off CTCSS tone or make sure both radios are set to the same tone on both Tx and Rx.
I cant get my baofeng to scan
I don't generally like Chinese radios but baofeng makes a great radio and I find it hard to believe it has anything wrong. have you dropped or pressed heavily on the scan button on this radio? how long have you had it? do you have a copy of the manual? what model is it?if you could answer my questions I may be able to help you, I have been using baofeng radios for years and prefer them to my yaesu radios. on the off chance that you have a bad unit, I have encountered 2 in five years and baofeng repaired both without question free of charge.
1helpful
My baofeng radio will transmit but will not reseive
Check your settings for the RX frequency. Then check to see if the RX Tone is turn on and is set to the correct frequency. Just turning the rx tone off should allow you to hear any station coming in.
I can transmit to my to my baofeng vr6 but i cant reiceve a transmit from it to my icom v85
Check the input output settings.
the baofeng is notorious for being somewhat difficult to program manually.
Try the software setup if possible.
1helpful
Get Motorola CLS 1110 to work with my Baofeng UV5r
Dear sir,
pls diable Interference eliminator code on baofeng,, & try the same
Baofeng UV5RA WILL NOT TRANSMIT
First, it's illegal to use that radio in the FRS bands. Also many of the Baofeng radios have very "dirty" output (spurs, frequency drift, bad modulation, etc). Your best bet is probably to buy another radio. With these radios about 3 of 10 I've tested have been bad.
Unable to transmit
The CTCSS codes are probably not set correctly. Baofeng manuals are notoriously hard to read. Look online (Google) alternative programming instructions.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
