Televison & Video Logo
n
noel thompson Posted on Feb 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Bravia KDL-4023100 has a white screen, still plays sound and displays
Nasir Muhammad
Level 2:
Champion:
  • Sony Expert 252 Answers
  • Posted on Apr 14, 2019
Nasir Muhammad
Sony Expert
Level 2:
Champion:
Answers
252
Questions
0
Helped
76847
Points
402
Hello Dear
in this case panel is defective please replace the panel
Thanks
M Nasir
5 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Jan 05, 2009
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Anonymous
  • 197 Answers
  • Posted on Jul 02, 2009
SOURCE: My Sony Bravia KDL-52W3000 panel is broken. Does
there are diferent versions of panel
Anonymous
  • 157 Answers
  • Posted on Oct 07, 2009
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Anonymous
  • 1284 Answers
  • Posted on Dec 02, 2009
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Anonymous
  • Posted on Aug 05, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
How to set Sony Bravia tv for sound only
Do you mean you want the TV to display no picture yet be playing the sound from a TV show? If so, sorry, there is no "audio only" setting for this model.
Sony bravia kdl-52w3000 picture and sound works for a while, then screen goes blank, sounds goes out
Does set do this on all inputs including one with a DVD unit connected and playing? Answer will at least narrow possible reason down a bit.
1helpful
2answers
Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
11helpful
AV2 sign won't go away when playing dvd
Press Info/ Display button on TV remote, on-screen display will disappear.
Thanks.
14helpful
2answers
When we have our Sony Bravia on AV input, it displays a clock at the bottom right. How can we stop this?
It is On-Screen Display. Press Info " i " button on TV remote so on-screen display will disappear.
Thanks.
Sony Bravia KDL-46Z4500 Captions
Try pressing the 'Display' button on top left of TV remote.
2helpful
Gray spot s on sony display
SOUNDS LIKE YOU HAVE A BAD LCD PANEL. TAKE IT TO A SONY AUTHORIZED SERVICER.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
