This kit below has your wiring harness and radio installation kit for that single din unit.
https://www.hifisoundconnection.com/Toyota-Corolla-2003-2008-Single-DIN-Aftermarket-Stereo-Harness-Radio-Install-Kit-SC2-RadioKit1579?utm_source=google&utm_medium=base&utm_campaign=GoogleBaseFeed&gclid=EAIaIQobChMIlbeXh__C4AIVxB6tBh04aA0PEAQYAyABEgJj-fD_BwE
Get the harness for your car. Any local stereo shop will have it. Also pick up the dash mounting kit. It will have the instructions to take your dash apart.
SOURCE: Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
SOURCE: replace the ignition switch for 1998 toyota corola
first, remove the steering wheel and then remove the top and bottom covers on the steering column
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
