SOURCE: HP F2200 All-In one driver installation failures
Normal
0
Normal
0
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: download drivers motherboad,audio drivers download,board vga down
Please follow this link to find the proper drivers for your motherboard.
You will have to choose the correct socket and model of motherboard.
Thanks,
Lolita
SOURCE: sound drivers problem
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3370405&lc=en&dlc=en&cc=us&lang=en
select your operating system and downlaod driver from here.
SOURCE: asus 1000h pc have cemra drivers required
1.Definitely you can get your drivers .
just go to ur webcam manufacturing site, click on download section click on drivers, enter its model number and download the camera drivers .
2. If you don't know the webcam drivers cd then connect to internet, uninstall all the old webcam drivers if any. then when pop up window says that new hard driver is found then click it and it will automatically install drivers from net
3. If you want to know about your webcam drivers, then go to desktop
a. right click on my_computer,
b.then select properties, in properties tab click on the HARDWARE tab,
c.then click on the device manager tab, then select and expand the drivers like sound or video which you want to know.
d. right click on the selected sound or display drivers and select its properties.
e. select driver tab and the driver name and version will be before you
for further assistance pls call me:- Thanks & Regard
Pravin jha
Great India
Phnno:- +919225600664
SOURCE: i HAVE EMachine T5048A PC.
well, i think i have a solution to your problem. download this software at this link http://www.mininova.org/det/2713589 and burn it as a cd-rom (you will need a bittorrent program. just go to yahoo and type in utorrent and download the freeware.). best thing to do is right click the download after it is done and open with nero burning rom or what ever burning program that will allow you to burn ISO files. after that is done pop the cd in but don't run it. then go to control panel, click on administrative tools, computer management, device manager,and find the icons with the yellow ( ! ) signand right click it and update driver. then it should ask you if you want to connect to internet. click not this time. then click next, and then click one that says install from specific location. then another window should pop up and click the include this location and click browse and find the drive that has the cd you put in and click on it. then click next and it should install that driver that you need. if that doesn't work then sorry to say but its your pc. let me know if that helps. good luck.
