Question about Casio Music
How do I reset from factory my Casio Privia Px - 7 Limited edition??
Every time I powered it sounded the modern tone but now every time is on the electric piano is the tone that's selected and it's annoying me. Thank you
Posted by Camila Lozina on
5 Related Answers
Fred Yearian
  • 5603 Answers
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Posted on Dec 01, 2009
Michial Gueffroy
  • 1140 Answers
SOURCE: Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Posted on Jan 21, 2010
Fred Yearian
  • 5603 Answers
SOURCE: Casio Privia PX-800: When using the sustain
Check if the cble frm the pedal MIGHT be flexing or pulling on the keyboard case when you use it. Such movement COULD vibrate the power connector causing your problem.
Make sure you have the right power supply for the unit as one with too large a hole for the power pin would be intermittent like this.
Posted on Jan 26, 2010
Fred Yearian
  • 5603 Answers
SOURCE: casio privia key issue
The only way to analyze this is to open the case. You may find contaminating material has gotten in, or broken part, or key slightly out of position on pivots or pivot plastic broken.
When opening, be VERY careful of the tender ribbon cables. Have a large work surface that you can unfold the top onto. Be careful to use correct screw lengths and thread in each place you removed.
Posted on Apr 27, 2010
Fred Yearian
  • 5603 Answers
SOURCE: Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Posted on Jul 14, 2010
How can i do the reset factory for a piano Casio Privia PX-120?? It have the tone/settings button but not the function button. anyone know?
You don't need to reset factory.
You just need to change the setting of LOCAL CONTROL.
Lets start :::
While holding TONE / SETTING button,press key D#7 at 7th octave (highest octave on the right hand). Then release. That's all.
Then the sound must be heard..
Mar 12, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
I connect the piano to midi and them the speakers stopped sounding, the phones plug too. how can i do the reset factory for the privia px 120?? thanks!
Lets start :::
Mar 11, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
How to reset?
factory reset Procedure.
Turn the keyboard off then press and hold the TONE and FUNCTION buttons while you turn on
Aug 04, 2014 | Casio Privia Px-130 Px130 88 Key Digital...
Privia 830 factory reset
TRY this;-
1. Turn off the digital piano
2. While holding down both the (TONE) and (FUNCTION) buttons, press the (POWER) button
Jan 11, 2014 | Casio PX-830 BK Privia
How to reset the Privia Px-110 back to factory setting
Try this
Nov 17, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
How can I do an internal factory reset for my Privia PX-130?
Turn the Keyboard off the press and while holding down the [TONE] AND [FUNCTION] buttons power on the keyboard. Wait until all reset is done.
Aug 22, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
Is there an internal reset for my privia 330?
to do a factory reset you Turn the Keyboard off the press and HOLD TONE AND FUNCTION and power the keyboard on while holding them buttons. if you did it right you'll see some wierd start up and flashes and then everything will be back to normal. try a few times if at first it doesn't work. somtimes it's picky.
Oct 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Is there a "Factory Reset" procedure for a Casio Privia PX-575R
Here is a link to the manual:http://ftp.casio.co.jp/pub/world_manual/emi/en/PX410R_e.pdf Page E-79 describes the procedure. Here is a link to their support page in case you don't have the CD that was bundeled with the keyboard:http://www.casio.com/support/
Oct 17, 2010 | Casio Privia Keyboard Case
Jul 13, 2010 | Casio Music
Music Logo
132 people viewed this question
Top Casio Music Experts
Ekse
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Casio Music Expert? Answer questions, earn points and help others
