I have that problem with my fi-6130 too, but the message specifically states "abnormality has occurred during communication." So the comments on paper jams (which I've not had) appear to be wild guesses unrelated to whatever is actually happening. But those messages are very old, so apparently their system is guessing what answers to throw at a question it cannot handle....
SOURCE: Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any
panel error message like J-1 on scanner start up?
If the issue
occurs during scanner start up, then there are staple pins or dirt might
be stuck inside the US Sensor panel inside the scanner. Cleaning and
removing the objects will resolve the issue.
If the error occurs
after few pages scanning, then you may have to check the Pick Roller,
Brake Roller, Pinch Roller and US Sensor FX status. you may have to
replace any of the above, if damaged or worn off.
Hope the above
information is helpful.
Please check your device first and get back to
me.
Thank you.
Regards,
TechSatya
Testimonial: "Hello TechSatya, The information you have provided is very helpful. We can now notice staple-pins stuck inside the Sensor panel. Thanks a lot."
SOURCE: fujitsu scanner fi-6130. i have
This is a 6130 model scanner? For power problems, it is either going to be the power adapter or the control pca board that is inside the bottom of the scanner. Make sure you are using the correct power adapter. If you happen to have a volt meter, then check the output voltage of the adapter with the meter.
SOURCE: I had to do a
Restore to factory settings: If you want to restore your computer to its original settings without recovery CDs. Note: If your system is the multilingual version, the operating system and language you choose when you first turn on the system will be the only option for future recovery operations. This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option. Before performing a restore operation, please check the BIOS settings. 1 Check to see if Acer disk-to-disk recovery is enabled or not. 2 Make sure the D2D Recovery setting in Main is Enabled. 3 Exit the BIOS utility and save changes. The system will reboot. Note: To activate the BIOS utility, press <F2> during POST. To start the recovery process: 1 Restart the system. 2 While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process. 3 Refer to the onscreen instructions to perform system recovery. Important! This feature occupies 15 GB in a hidden partition on your hard disk
