Question about Shop Vac Vacuums
Can i by-pass the rocker switch with a toggle switch on my 12 gal shop vac?
Posted by James Leisinger on
5 Related Answers
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Posted on Jul 16, 2008
Anonymous
  • 867 Answers
SOURCE: Shop Vac was working fine last time I used it.
try tapping the motor area with a piece of wood or something, damp usage may have seized it up a bit
Posted on Jun 24, 2009
A Miller
  • 8404 Answers
SOURCE: My Shop Vac 90L600A is getting electric thru the
Check the othere end of the switch. You may have a brushes problem in the motor. You will have to check the switch while hot - be careful
Posted on Dec 20, 2009
Testimonial: "I was very satisfied with the information they provided. It was more than I expected to receive when I started."
Anonymous
SOURCE: I need a manual for a Rigid 5 gal shop vac or a
open it up. the manual is inside.
Posted on Mar 06, 2010
pappapumpdaf
Bob Sloan
  • 635 Answers
SOURCE: genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Posted on Mar 11, 2010
Testimonial: "I have a lot of upright vac bags from long gone vacs & I hadn't thought about cutting one down! Good idea, now I've just got to go get a foam filter."
I have a rigid 16 gallon shop vac I plugged it in and pressed the toggle to on but nothing happens is there a reset somewhere
Not likely.The on-off switches are cheap plastic, and you will likely find the switch, the plug, the wire, or the motor has died.
Sorry.
Jun 04, 2018 | Shop Vac Vacuums
Need a new off on switch 20 gal genie 4.0 shop[ vac
Go here and enter your SPECIFIC Model Number:
Parts Lists
If that does not help, search GOOGLE for this:
Genie 20 gallon 4.0 shop vac power switch
Genie 20 gallon 4 0 shop vac power switch Google Search
Anthony
Jun 02, 2018 | Vacuums
I need a rocker switch for a Shop Vac 86798-53 (LB550B)
Amazon is your best bet. Type in 120 volt rocker switch
Apr 28, 2016 | Shop Vac Vacuums
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
Vacuum shut off and will not turn on again. What could be wrong?.
Your switch died, it happens a lot with this brand of shopvac. Just extract the little switch behind the big rocker switch and replace it with one from radio shack, or replace it with a toggle switch. Cheap and easy to do.
Mar 15, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
Oct 25, 2009 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop vac QPL625 on off switch stays on.
Contact Digi-Key 1-800-344-4539 or 218-681-6674 ask for part number EG1505-ND.
Cost is about $2.00 plus shipping.
See http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=EG1505-ND for part details.
You want a D.P.S.T (On/Off) mini-rocker switch.
Apr 16, 2008 | Vacuums
Vacuums Logo
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Bill Johnson
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
