Purchased 5 yrs ago, worked properly, after few years of no use, they do not react any more on w10. They are in perfect state, no visible mechanical damage.
SOURCE: my logitech speakers are not working properly with
connect the computer speakers to a working green sound port on the back or on the frnt of the computer>
then check if the Realtek driver is upgraded to the latest update>
go to control panel> sound properties> playback devices should be speakers
SOURCE: logitech speakers installation guide
Here is the link so you can download a manual: http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=8263&p_created=1158961578&p_sid=h_qp_7hj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9ODQ0LDE3LDE2OTQmcF9jYXRzPSZwX3B2PTMuMTY5NCZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PW1hbnVhbA**&p_li=&p_topview=1
SOURCE: Logitech cordless internet handset for skype -- base unit problem
You can uninstall the Skype Application and reinstall it in compatiblity mode and chose XP. To do this right click on the install exe and go to the compatibility tab/section and from the drop down chose XP. Then try reinstalling it.
That has solved a lot of issue for me with Vista.
Let me know if you need anymore help or if that does not solve your issue.
Thanks,
CompGoddess
SOURCE: logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
SOURCE: Logitech R-10 speakers
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
