Medical Logo
B
Bruce Leitkam Posted on Feb 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code #3 on spacelabs burdick elite II - Medical
Stephen Miller
Level 3:
  • Master 1,645 Answers
  • Posted on Feb 14, 2019
Stephen Miller
Master
Level 3:
Answers
1645
Questions
0
Helped
866176
Points
9471
How to run diagnostic on Kenmore elite smartwash quiet pak 9 HE4t washer? Model#110.45087401
Diagnostic mode for Kenmore Elite He3t model 110 42926 ...
iFixit https://www.ifixit.com > Answers > View > Diagnostic...
Apr 8, 2016 - With the washer empty, close the door. · Push "control/on" or "Start" · Select "Drain/Spin" · Select "No Spin" by pressing SPIN SPEED touchpad.
3 answers · 2 votes: I believe this is very similar to the model I have. Here is what I did to run a diagnostic. ...
F11 error code during Diagnostic test? - Kenmore ...
1 answer
Jan 18, 2016
SOLVED: F11 code error on Kenmore HE3 - iFixit
Mar 3, 2011
SOLVED: f h error code - Kenmore Elite HE3 ...
Feb 21, 2012
It seems like the washer has no power - Kenmore Elite ...
Nov 2, 2017
More results from www.ifixit.com
Diagnostic Test; Starting The Test Mode; Test Program ...
ManualsLib https://www.manualslib.com > ... > User manual
Close the door. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button five (5) times. Push Prewash Option button four (4)times within ...
What does error code 4 mean on an Burdick Atria 3000 ECG?
I have just reviewed the service manual and unit operating instructions. There is no data available related to error codes. Since this is a medical device, recommend contacting a qualified service provider for assistance.
Oct 03, 2018 • Medical
How to change from lunch to day mode
These phones work on about 8 NEC systems, but for a PRO II, an Elite, and an IPK, the standard code is Feature,80, Feature from one of the two main reception extensions. Don't know the code for a 2000, 8100, or IPK II.
Iterra elite II printer showing fatal error 131 code error
Error Code: -131, ErrorMessage: Connection to license server failed; if license server address is invalid, correct it; if TAO NT naming service stopped, activate it and restart License Manager
I was sure that all SAP B1, and MS SQL services are up, and running on the server side so I knew this is an issue related to the client side.
The solution was checking the file "b1-local-machine" which is located it under "C:\program files\SAP\SAP Business One DI API\Conf"
The value of the server ip was "localhost", and it should be the ip of my production server instead.
Hope that was helpful.
for more hrlp visit CBR Tech Solutions
79helpful
10answers
Minolta Dimage Scan Elite 5400 - Vista driver?
1) Install all of the usual Minolta software in Vista if you haven't already.
2) Create a new folder somewhere
3) Create a new txt file in that folder and name it minolta.inf and paste this into it:
; minolta.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. Once installed, all the normal Minolta programs now work just fine. Enjoy!
I tested this on Vista 32 Ultimate with a Dimage IV but it should work on all the models listed in the .inf file.
2answers
MINOLTA SCANNER DiMAGE SCAN ELITE 5400 II
My 5400 2 scanner worked well with windows XP but will not start with my new computer WINDOWS VISTA.
ERROR message Can not find scanner, check connection
ERROR message 1 unknown error
The scanner was purchased new 1-2006
my installation dick is for Win. XP Version 1.0.1.
Top Medical Experts
Don A
Don A
ADMIN Andrew
ADMIN Andrew
Are you a Medical Expert? Answer questions, earn points and help others
