Question about Hotpoint WMA58 Front Load Washer
Is it possible to change bearing on a Hotpoint Aquarius WMA58? and if yes, can i do it my self? thx
Posted by rorymcnally6 on
Barry Coates
  • Hotpoint Master
  • 3,463 Answers
You can do it your self, but it is a very involved repair, and I would not recommend that you attemt it, unless you are conversent with washing machines, it involves a complete strip down.
Please rate my solution.
Thanks.
Posted on Aug 20, 2009
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Hotpoint wma58 stopped spinning
unplug it for a hour plug back in see if it resets it self
Apr 05, 2014 | Hotpoint WMA58 Front Load Washer
MY HOTPOINT AQURAIUS WMA58 IS NOT DRAINING WAT CAN THE PROBLEM BE
The solenoid in your drain valve has stuck closed or otherwise failed.
OR: the discharge hose has clogged or kinked.
Check;
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
Mar 27, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
H, can a hotpoint aquarious wma58 be run on cold water supply only.
if you have two connections on rear then no hot and cold needed .. if one just cold water.. bsc appliances 07779933829 spares and repairs
Feb 27, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Help to change bearings
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Apr 16, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius wma58 door will not lock
door lock has blown, will need replacing on many of these machines when the door lock blows it also takes out the control board. first stop tho change door lock
Mar 29, 2010 | Hotpoint Washing Machines
My 13 year old wma58 makes a lot of noise on spin rinse
To be certain if it is the main bearings, remove the lower rear panel of washer, remove belt, and spin drum from the front.
If it feels rough or is rumbling, then the bearings have failed..
If no noise from drum then it could be noisy motor bearings.
At that age, it certainly would not be cost effective either way.
Hope this helps.
Dec 16, 2009 | Hotpoint WMA58 Front Load Washer
Bearings need replacing
For all your parts visit our site http://www.apart4u.co.uk
Sep 30, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WASHING MACHINE.
at back, take small bottom panel off. you will see a large diameter hose going from bottom of machine to the pump. undo this hose at the machine end and the filter is inside the hose. take out and clean.
be carefull, lots of water will come out if the machine has not drained.
best to disconnect from mains when you do this
Aug 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA58 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
