Question about AOC Computers & Internet
Need a manual for the AOC LCD monitor model #21500032
Posted by Hudie Evans on
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
Atiq
  • 257 Answers
SOURCE: AOC color monitor model 9g1rs, dead, ** volt, fuse good
Hi
You need to replace HOT(Horizontal Output Transistor) see number carefully before you replace it.
Posted on Mar 18, 2008
Anonymous
  • 43 Answers
SOURCE: aoc LCD monitor problem
If some of the pins inside the monitor cable are bent or broken you can losr primary colors and cause this. Check them. If they seem OK try reseating both ends of the cable. If no go, then try the monitor of a differnt computer to see wether its the videocard or the monitor thats defective.
Posted on Jan 06, 2009
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: I need a manual for a 22" AOC monitor
Suggest you go to AOC Support, Downloads>Manuals, and type the exact model of AOC monitor that you have.
Download the User Manual.
For example:
http://us.aoc.com/support/downloads
Product Category:
Left-click on the blue down arrow, to the right of this box.
Left-click on LCD Monitors
Model Number:
Left-click on the blue down arrow to the right of this box.
Scroll down, and left-click on the model number of your AOC LCD monitor.
After you have done this, a drop down menu will appear.
Where it states your monitor's model number, and the word - MANUAL, go to the right, and click on the white - Download.
The User Manual is in PDF file form. Give it a few seconds to download.
Posted on Jan 03, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: AOC LCD MONITOR
The cable from the Monitor USB input to PC USB output is good? Check to see if you do have 5vdc on pin 1 of the USB connector. Your monitor is basically a powered USB hub when it is connected to PC through a USB cable.
Posted on Jan 20, 2010
How to set up aoc lcd monitor
Plug in the power and connect the display cable to your computer
5helpful
8answers
Hi
How do u get to the menu on my aoc lcd monitor
hi
Depending on the brand and model of your monitor, there may be extra features that require special troubleshooting tips, or there may even be alternate ways of troubleshooting basic problems. For this reason, it is important to keep your user manual.
If you have come across an issue with your LCD monitor that cannot be corrected through the basic settings, you should consult the user manual to determine troubleshooting solutions for your specific monitor.
For example, The AOC 175F LCD monitor features a 90-degree rotating display, which, in order to rotate correctly within Windows XP, must have AOC's third-party software installed. This is not something required of all LCD monitors, as not all LCD monitors offer a rotating display.
If the troubleshooting section of your user manual still does not solve the problem, it may be necessary to contact the manufacturer's support team (via phone or web) to discuss what is wrong with your monitor
2answers
For example:
Product Category:
Model Number:
3helpful
1helpful
2answers
I can't find aoc 210s drivers. Where can i get
Please follow the below link
http://www.voiceofchinese.com/techs/aoc-210s-2210s-lcd-monitor-drivers-for-windows-xp-vista
Please download the drivers from below link
http://www.voiceofchinese.com/files/AOC-210s-2210s-LCD-monitor-driver.7z
I believe your problem will be solved
HELP
The AOC Envision A17W221 only has a NTSC tuner (analog). If you are using an OTA antenna, you probably need a digital (ATSC) to NTSC converter box to get any TV signals. These include the ones sold with the government coupon at the switchover. Very few analog stations still broadcast; they were limited to low power transmitters. Thus you need to be close to the transmitter to receive a watchable TV program. For the best signal to the AOC A17W221, connect the component video out on the converter box to the component in on the TV. The specifications for the A17W221 are available on the Amazon sale page, https://www.amazon.com/International-A17W221-17-Inch-HD-Ready-Panel/dp/B0009IRHL8/ref=cm_cr_arp_d_product_top?ie=UTF8 . This monitor is no longer available from Amazon but the site is still there. Newegg also has the specifications for this monitor.
Unfortunately, I can't find the manual for the A17W221. AOC only lists a few manuals for current models. These are available here: http://www.aocmonitorap.com/my/user_manual.php .
I hope this helps. To check for available stations in your area, use a site like antennaweb.org or tvfool.com. Antennaweb gives very conservative estimates on stations that you should be able to receive with an external antenna.
Computers & Internet Logo
Top AOC Computers & Internet Experts
Ekse
Raj Patel
Mehandi Husain ...
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
