SOURCE: Rechargeable lawn mower lacks power
just to let u know CMM1000 mower are on recall for pcboard.
if ur mower is type 1 to 4 then its the subject for recall for convertion to CMM1200.see ur nearest service center right away.
SOURCE: Bad battery
A replacement battery can be purchased from Sennheiser for $20.00.
Battery Part Number: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
SOURCE: dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
SOURCE: IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
SOURCE: Got overload message; batteries were a year old so
Overload has nothing to do with the batteries being old or new...it has to do with with how much watts you are sending through the unit...if the overload protection fault is on, it is because it is sensing that if the power were to go out the UPS would not hold up the load at all. I do not recommend to load the ups more than half of the load. visit a batteriesplus store near you and they can help you with this in more detail. www.batteriesplus.com
