SOURCE: Miele Washing Machine - Novotronic W827
Give the door a firm push shut (even if it appears shut already). There is a safety mechanism that stops the door opening when drum is turning and it gets its knickers in a twist sometimes. Happened to me twice in the last 5 years and can never remember how to fix so end up ringing Miele support who are always helpful. Next time I'll look here first!
SOURCE: Newly installed integrated dishwasher will not start
have you checked that the water inlet pipe is not kinked or that it is turned on. some models have water pressure sensors and wont work on low pressure supplys
SOURCE: smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
SOURCE: Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
SOURCE: fridge/freezer in a motorhome has
I am guessing this is a "three way fridge" 12 volt, 240 volt and lpg gas.
This is an absorbtion refrigerator and it uses heat to drive the cycle.
The things to do are;
Clean the gas jet, Piezio starter and thermocouple.
Also clean the rust, carbon and scale away from the heater tube and chimney.
Hopefully all will be good again
