Resetting a klangtop mp3. will not return to main menu.
Posted by eliz101074 on
Stephen Miller
  • 1,645 Answers
1 Related Answer
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Posted on Nov 04, 2009
How do I return to the main menu
Hi
By pushing "return" until you come to the main menu.
Kolbrun
Mar 11, 2012 | Audio Players & Recorders
Can u help me to deleting everything on my MP3 player. All the files r corrupt. Doesn't allow me to delete or add music. Has these stange language or symbols that arn't deletable? Is there a way to reset...
Hi, follow the instructions below to reset your Nextar mp3 player
To customize the player settings:
(1) On the main menu, select the “Settings”item and press the MENU button to enter the
system settings mode.
(2) Press the PREVIOUS/NEXT button to select setting item and press the MENU button to
confirm or press the PLAY/PAUSE button to cancel/return.
(3) System
(4) Load Default - Restore the player to default setting
Take care
Feb 18, 2010 | Nextar MA797-20 MP3 Player
Need to return sandisk sansa clip+ 4gb back to factory default. Is there a way to do this?
When you are able to go through the player's menu you can select reset factory settings. Starting from the Main Menu select:
1. Settings menu
2. System settings
3. Reset factory settings
4. Yes (to confirm the selection)
Manual for the Clip+ in pdf format:
http://mp3support.sandisk.com/downloads/um/clip+-en-um.pdf
Just post a comment, when you need more help.
Jan 06, 2010 | SanDisk Sansa Clip MP3 Player
I pod
have you tried resetting it? you can reset it by holding the menu and the center button together if that doesnt work it means that the screen is broken
Jul 09, 2009 | Apple iPod nano
Audiobook loads but does not play. Tells me to sync
Reset All This will reset the player to its original factory settings.1. Press Menu to return to the Main Menu. 2. Move to Reset All and select it. 3. Select Save to reset to factory settings or Cancel to stop
May 06, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 1gb mp3 player
You will have to fly blind a bit, but remember that the Spanish word for language is "idioma" and the Spanish word for English is "Ingles" - Here is a link to the user manual that will help you - Sansa does have a Spanish version of the manual if you want to compare. Eventually, you want to find this menu/setting:
Reset All
3. Select Save to reset to factory settings or Cancel to stop.
www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa m240 MP3 Player
I use my sansa clip for audio books.
Reset All
-Tha Mp3 Doctor
Dec 15, 2008 | SanDisk Sansa Clip MP3 Player
Keeps power off when i want to play a song or use the fm function
    Please find reset button and reset it.It will start working.
Thanks for using fix ya.
Oct 08, 2008 | Sony NWZ-B103FBLK MP3 Player
Playback Speed
Reset All
-Tha Mp3 Doctor
Sep 10, 2008 | SanDisk Sansa Clip MP3 Player
593 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
