HP Officejet J5780 All-In-One InkJet Printer Logo
Posted on Aug 05, 2009
Aligns cartidges and prints test sheet, after it does this, it tells you to align paper and after youve done that, the cartridges wont align after printing the test sheet. what should i do tried many troubleshooting steps none have worked
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
198
Points
6
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
My HP PSC 1315 printer/scanner prints the test page every time I turn it on. A 2008 post from littlebluemuffi helped until now, but today it still printed the test pages.
This usually happens if the printer is not aligned properly. When you replace the cartridges, it prints a colorful sheet of paper. You need to place the paper face down on scanner glass and press OK button.
This completes alignment and the printer wont print test page again.
Regards,
Sean
4helpful
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
3helpful
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Align the print cartridges
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
Score the solution and download the manual if you need it
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
1helpful
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
k24674
Grand Canyon Tech
Grand Canyon Tech
