Question about Electrolux Washing Machines
Can you turn off your overdrive? When towing most vehicles have an overdrive off mode. You can’t tow in 5th or 6th gear and may confuse computer and put car in protection loop mode.
Posted on Feb 13, 2019
Testimonial: "Haven't tried towing with this model washing machine, didn't know it could."
SOURCE: washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Posted on Jul 20, 2010
SOURCE: electrolux ew 880 f. Working
Disconnect the power supply for few minutes, say 15 minutes and then turn it on. This would reset the machine.If the problem persists, this would more likely confirm an internal issue and needs repair.If you wanted to repair it, kindly provide few more details :-
1. How old is the machine?
2. Any error message on the display?
3. Any sequence of beeps like 3 beeps, then pause and then 3 beeps or is it beeping continuously?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 14, 2011
SOURCE: Hi, I have and Electrolux
(pre-typed to save time- common problem!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 24, 2011
