Question about Home Security
SOURCE: Canon Digital Rebel XT Bulit-In Flash Strobes in Low Light
use more light:)
its very normal that it does that. it dosent get enough light so it
cant focus. the only way it can autofocus is that it stobes the flash
to adjust the focus automaticly. use an external flash like 580EX and u
will get an focus asisten thru a red grid throne by the flash unit.
Posted on Nov 20, 2007
SOURCE: help with kyocera strobe on alltel network
I asked Alltel customer service and they said the phone is not capable of it. Mine come through as symbols. I just bought this phone on Ebay but it will be back on Ebay shortly.
Posted on Mar 25, 2008
SOURCE: My Vizio VX42L is flashing like a strobe light.
Mine did the same thing. Remove the stand and back of the tv. Be careful with screen do not lay on hard surface and scratch. When you take the back off you will see a board on the left side and a board on the right side. They are labeled slave and master. Remove the ribbon cables and take board out. There are 2 capacitors on each board (about an inch long). These are probably all bad (ends bulged a little with black stuff on bulged end). Radio shack has them for less than $2.00 each. turn the board over and you can read the size of the capacitor. You need someone who can use solder wick and remove all four capacitors and solder in new ones. Notice how the capacitors are turned. Each one is labeled with a dash for negative. Make sure you bend new capacitor connectors the same and put back in the same way. Put the boards back in the tv and attach all ribbon cables. Put back and stand on. hook up your power and cable box and you are ready to watch tv with no more strobe. Me, my husband, and son did ours last week. I looked up the problem on the internet, husband removed stand & back, son with the steady hand did the soldering. Family project that went well for once.
Posted on Jun 25, 2010
SOURCE: My Hayward Colorlogic pool light is flashing like a strobe light.
That particular swimming pool light has a power-cycle feature that allows you to change the way your light illuminates your pool simply by turning it off and on. A strobe like effect is one of these power cycles. To change it, simply turn the switch off and then turn it back on within 10 seconds. It should reset to another cycle. It is is left off over 60 seconds, it resets to the first cycle, which could be the strobe. If cycling doesn't solve the problem, your bulb has probably malfunctioned and you are going to have to have a repair tech service it.
Posted on Jul 14, 2010
Jul 26, 2017 | Home Security
Sep 05, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Apr 30, 2010 | Olympus FL-20 TTL Flash
Nov 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Jun 19, 2007 | Canon SPEEDLITE 580EX TTL Flash
227 people viewed this question
