SOURCE: cannot transfer any files from my computer to my external hard
Did you install the drivers for the drive? Is it recognised in Windows as a device? If not, try reconnecting and Windows should prompt you to install the drivers, Assuming the drive is recognised by WIndows, then are a few causes for not transferring data. I've attached a link to Western Digital's FAQ regarding Data Transfer problems with your drive....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_alp.php?p_sid=nCt181pj&p_accessibility=0&p_redirect=&p_lva=1017&p_li=&p_page=1&p_new_search=1&p_search_type=answers.search_nl&p_sort_by=&p_search_text=transferring+data
Several page of possible solutions are listed above.... however, you can refine the search if it is only happening when running specific apps or @ specific times. The answer you seek is located in this link. If you can provide more details on the type of file(s) you are trying to transfer and how, I'll refine the solution for you....
SOURCE: short self test failed
Your best option here is to take the drive to a data recovery specialist.
If you google data recovery it will come up with some sites where you can find local offices to do this
SOURCE: I HAVE A HP DV6700 LAP TOP HOW DO YOU CHANGE THE HARD DRIVE
The official service guide:
http://h10032.www1.hp.com/ctg/Manual/c01295877.pdf
Testimonial: "THANKS IT HELPED A LOT"
SOURCE: how to avoid formatting drive
What did you format to,fat,fat32,NTFS,
I am not sure if your saying you had it on a desktop pc and now you plugged it into a laptop, or its always been on the same computer
and it just wants to format.
Either way, a computer should not want to format, usually you have to tell it to format, and the only reason to format a hard drive whether internal
or external ,is to change the file system from one to another,
example; FAT to NTFS , or your going to install a operating system to the hard drive.
Its sounds like you had it in a computer whether the same one or a different one, and you did not use the safely remove hardware, or you unplugged it while it was writing data back and forth.
Turn both off, the computer and external hard drive, plug the hard drive
into a different USB port, or firewire, how ever it connects.
Now turn on the external hard drive, wait a few minutes, now start the computer, once in windows if you see this I want to format you hard drive, tell it no, go to control panel and open devise MGR, and look for a yellow shield, under Universal serial bus controllers , the one that has a yellow mark, right click on it and choose properties, read what it says
in the open box, if it says disabled, enable it, if it says no driver,
click on driver tab, and click update driver.
