The machine grinds the coffe but it stays in top coffe very light
Hi
The first thing I would do is this. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
If that didn't work then you have to clear the clog. Try removing the brew group. Then inside on the roof of the machine where the brew unit was, there is a drop chute where the coffee is dropped into the brew unit. From the front side of the drop chute pull down and left, and it will drop coffee. This will clear an opening, and that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder (towards the back). Vacuum it out. It will be on the right side of the drop chute.
