Hey guys , i got a 13kg defy top loader . The thing washes and rinse but with a full load when it goes to spin , the drum hit the walls , realy dont have a clue of why its doing so . When i take same of the washing out it spins fine , but when loaded , not a thing
Posted by Heinrich Campher on
  • Heinrich Campher Feb 22, 2019
    Thanx for advice , its working fine now
Jayesh Panchal
    Sergeant:
    Champion:
  • 279 Answers
Balance of washing machine is not proper , Adjust front leg for balance of washing machine
Posted on Feb 12, 2019
5 Related Answers
Anonymous
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
benham
  • 125 Answers
SOURCE: LSQ9549LWO WHIRLPOOL WASHING MACHINE TOP LOAD NO SPIN @ RINSE CYCLE
You could have a bad lid switch or the hinge may need to be bent to make better contact with the switch. If your washer has a oval cut out on the right side and an actuator on the rt side of the lid... the next time it acts up don't open the lid and turn the tub, simply push down on the rt side of the lid, if it starts to work replace the lid switch. If there is no hole or actuator on the rt side, then the lid switch is on the back left corner, when you open and close the lid you should hear a click. If you don't hear a click or if you hear it when the lid is almost closed you need to adjust the hinge. There are 2 screws on the back of the endcaps on the control panel remove them and flip up the control panel, use a screwdirver to pop out the spring clamps on the rt and lt sides of the top panel. approx 3-4 inches from the sides. just insert the tip into the front most part of the clamp and pry back. unclip the lid switch, and pull the cabinet forward. You should be able to bend the hinge a little so it makes better contact with the lid switch. hope this helps.
Posted on Aug 22, 2008
Anonymous
  • 261 Answers
SOURCE: Top load washer Admiral # AAV7000AWW
I would replace the belt part # 21352320 which cost about 20 bucks. Tilt the machine back when off and empty and look for a glazed belt with maybe some cracking and wear.
Posted on Oct 04, 2008
Anonymous
  • 127 Answers
SOURCE: Direct Drive Kenmore Washing Machine will not spin
its possible the ears on the top of the drive tube have worn alowing the basket drive block to slip and not turn the clothes basket with authority, or the basket drive block has just worn from overloading and needs replacing.. is easy to verify by looking..
best of luck,
ttfn
Posted on Oct 25, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: GE WSSH300 front load washing
Welcome to FixYa
It sounds like (based on your initial description) the unit is detecting an incomplete drain or an unlocked door, hence the control will not initiate a hi-speed spin. Since you've checked the drain already you can likely rule the incomplete drain a non-factor.
I know most folks will rule out the lock initially because the unit does indeed "lock", however, the lock on these machines are a two part device, a set of contacts to lock and a secondary contact to activate hi-speed spin, i.e.
If it does indeed drain fine, then here's the next place I'd direct you to investigate.
**Unplug the unit from the wall first...safety first**
It will require you to visually inspect the control board, thus needing to remove the top panel by way of taking out the screws at the back and sliding the panel back and up.
What to look for specifically is the wires with the green connector fastened to the board securely...I've seen a few vibrate loose thus preventing the unit from spinning, i.e.
If loose push it all the way in until it cannot be pulled out with a slight tug ( there are clasp's on the connector but I suspect sometimes they aren't secure when leaving the factory...just my suspicion )
If these things can be ruled out, then it is quite likely the door switch, so here's how to change/access the latch assembly...
**The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, ASIDE FROM PUMPS BEING OBSTRUCTED.**
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Mar 02, 2011
Testimonial: "thanks we tried everything else and am now ordering a door lock"
DEFY top loader washing machine and replacing the nano filter
I found this
How do replace Defy top loader nano filter please
As it is a very obscure model from South Africa and we are all North Americans, it might be better to contact the maker direct.
I'll correct all your spelling errors including the maker of the machine!
https://www.defy.co.za/product/nano-filter-top-loader-dtl125dtl130
Oct 23, 2018 | Washing Machines
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
What is leaking under my Amana washer during spin cycle?
Unlikely as the water is pumped out during washes and rinses. As you say it is only during spin, my view is that you have a crack or a split in a hose or a plastic part which is opening up due to the movement or vibration of spinning. The other possibility is a bad seal at the top of the drum on a top loader, or somewhere on the outer case of a front loader. A full strip of the outer panels is the only way. You can do a wash and then tilt the machine backwards against a wall and use a flashlight to look up inside.
Feb 19, 2018 | Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
How to operate top loader brandt malice AA washing machine
Hi guys! Please help me. I used the Brandt Malice top loader with a horizontal drum. I don't think the doors on the drum were clipped closed properly and now when I open the machine the drum is not facing up so I can't open it? It also won't spin. What do I do? There is clothes in there and the machine is off, but the drum seems stuck? Please help!
Sep 29, 2013 | Brandt WFH1176 Front Load Washer
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Prodigy washer
try with another preset(got 14), and see to compare whats happens, any way as another (dont remember who) tech of this forrum say, "if it not broke dont fix it"..good luck
Aug 10, 2006 | Whirlpool AWM029 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
