I had the same problem on my model MV-1310B. I replaced the stirrer fan and it lasted about 5 years before ity began sparking again. I found that keeping it clean from spattered food reduced the occurrence. I am about to order a second one. :( I attribute it to a faulty finish that allows it to burn away over time.
SOURCE: goldstar mircowave model 1310b parts manuel
Assuming that model is MV-1310B, that would be your stirrer fan cover, part number 3301W2A017A, which you can get from Encompass here or by calling toll-free at 866-779-5835.
If you need new clips / rivets for it, they are part number 4051W3A001A.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: I have a MV 1310B GOLDSTAR microwave. I can not
Unplug the microwave and try using a small pick to pull on the tab inside the socket a bit. Sometimes a replacement bulb like that is just a tiny bit shorter and will not make contact. Again, MAKE SURE IT IS UNPLUGGED FIRST!
SOURCE: goldstar microwave model mv-1310B problems,
in
99 % of cases the problem is the magnatron it is a very expensive part
and unless the microwave is well worth the money we normally write the
units off
sorry (
but i hope this helps
best of wishes
please remember to take the time to rank this reply .
SOURCE: I have a Goldstar microwave
well the Teflon has a hole in it exposing metal if it is in that shape id say its kinda old microwave i would just replace it if i were u
