SOURCE: Connecting the camera via USB hub.
Use of a USB hub for connection does not guarantee normal operation. Try attaching the USB cable directly from the D-snap SD Camera to one of the built-in USB ports on the PC.
SOURCE: PC Chips M957G MB. Can the 4 rear 4 USB ports easily be replaced?
hi there,
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
SOURCE: Playstation 2 Rock band disc error and no power in usb ports
There is a piece dust on the CD reader eye. there is two ways to fix this. 1. bye a disk cleaner any wal-mart or 2. take the unit apart. and clean the tiny glass laser eye your self using a cotton swab and alcohol. WARNING! never take any thing apart while it is plugged in. O TRY PLAYING A DVD IN IT AND SEE IF IT WORKS OR NOT IF NOT THEN YOU KNOW ITS DUST ON THE LASER LENS.
SOURCE: USB
First of all, I recommend you to Uninstall the USB Devices from the Device Manager and reinstall the Chipset Drivers as per the instructions below :
Click on Start and then on Run.
Type devmgmt.msc in the Run Command box and click on OK.
This will open the Device Manager window.
In this, click on the + mark next to Universal Serial Bus Controllers which will display additional USB Entries.
Right click on each of the entry and select Uninstall.
Click on OK if you get any confirmation window. Repeate the same process untill there are no entries left under Universal Serial Bus Controllers in the Device Manager window.
We are done with uninstalling the USB Drivers from the Notebook.
Now, restart the Notebook and close any window which says 'Found new hardware'
Now, download and install the Chipset Driver in your Notebook from the link below :
http://downloadmirror.intel.com/8178/a08/infinst_autol.exe
Save the file in the Notebook and double click to install the Chipset Drivers.
However, if the issue with the USB Ports persists, I recommend you to check again with different devices to confirm if the issue is with the USB Ports of the Notebook itself.
If the Notebook doesnot recognize any of the USB Devices after installing the Chipset Drivers, you may need to get the USB Ports of the Notebook replaced or go with a PCMCIA USB Card.
Hope this helps....
SOURCE: TV USB Input - Displays mp4 video from laptop?
this is not true..flash drive yes can carry audio/video, but unless there is some sort of media player to read the file while plug to usb...some tv monitor can open (jpeg files) photos (slide show) but not video
