Question about Frigidaire Ovens
Baked on tin foil on the bottom of my Frigidaire oven
I purchased a new Frigidaire oven about two years ago - regular and not convection. I unfortunately put foil on the bottom and some of it stuck. I dont' know how to get it off. I have tried soda and vinegar and other things but it hasn't worked. Any suggestions?
Posted by Judy Van Hooser on
  • George Scott
    George Scott Feb 12, 2019
    I don’t like the wd 40 chemical -let the oil sit if it’s a pan take it out stand it on end pry a end loose let the oil run between foil & pan
George Scott
    Master:
  • 789 Answers
Olive oil because thats what i have
Posted on Feb 12, 2019
Testimonial: "Oh wow. I’ll try it. Thanks bunches!"
Kardoc
    Top Expert:
  • Frigidaire Master
  • 5,764 Answers
Try the liquid that mechanics claim to do all. WD-40.
Testimonial: "Hmmm....interesting. If the olive oil doesn’t work, I’ll give it a shot. Thanks!"
2 Related Answers
robert samples
  • 1314 Answers
SOURCE: tin foil stuck to bottom of oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Posted on Dec 29, 2007
Anonymous
SOURCE: tin foil baked on the botton of a convection oven
Sparkle Toilet Cleaner,  Saturate  aluminum with it! contains hydrochloric acid, just eats it away until its gone , smokes a bit but does not harm enamel!
Posted on Jan 28, 2010
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
How would I remove aluminum foil stuck to the bottom of a convection oven?
Aug 04, 2010 | Electrolux Ovens
Tin foil baked on the botton of a convection oven
Oct 31, 2009 | Kenmore 33169 Gas Single Oven
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Foil baked onto oven base.
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
Jun 07, 2008 | Ovens
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
Tin foil stuck to bottom of oven
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
This is an electric convection oven
I am by no means an expert, but I believe the only thing differenty in a convection oven vs a regular oven is that there is a fan to conduct the heat quicker and more evenly. It has to do with heat tranfer rate. I can't imagine why aluminum foil would cause any problem.
Aug 21, 2007 | GE Profile JT915 Electric Single Oven
Ovens Logo
186 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Ekse
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
