Question about Homedics Health & Beauty
Homedics Hand Wax machine is not heating up today but it worked fine yesterday. What happened?
Posted by Carol Cappiello on
5 Related Answers
Anonymous
  • 490 Answers
SOURCE: Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Posted on Apr 13, 2009
tony2155
Tony Houde
  • 64 Answers
SOURCE: Dryer runs fine but no heat
change the fuse in back of the dryer
Posted on Jun 23, 2009
Anonymous
  • 44 Answers
SOURCE: worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Posted on Feb 07, 2010
Joe Hogan
  • 10865 Answers
SOURCE: has no manual
hello... here is the link to the closest product now shown at homedics http://www.homedics.com/home/spa/paraffin-baths-wax/paraspatm-plus-paraffin-bath.html
before you go to that link you will see that the item is out of stock and the manual does not load up.
You can call the company and ask for the manual Phone: 1-800-466-3342 (1-800-HOMEDICS) Consumer Relations hours are 8:30am to 7:00pm Eastern Time, Monday through Friday.
please rate my answer as very helpful thank you. joe
Posted on Mar 26, 2010
Anonymous
  • 19 Answers
http://www.homedics.com/home/FAQ-paraffin-bath/
Here is a website that you might find helpful. Also here is the website to contact homedics customer service. You could get them to send you a manual. http://www.homedics.com/home/contacts. They should be able to help you. There is also a website called manualsonline.com. You can download tons of different manuals from there. I hope this helps! :)
Posted on May 18, 2010
Microwave starts and runs but does not heat
hi, this usually happens if metall is put in it, usually means a replacement is required. You can try to diagnose and fix but it may be more cost effective in the long run to replace
Jun 08, 2015 | Microwave Ovens
Do you have the instructions or user manual for Homedics Paraffin Baths from several years ago.
I have the manual for the ParaSpa Plus. Your image matches the model. Do you have a specific question?
Sep 27, 2013 | Homedics Paraspa Plus Paraffin Wax Bath"
I have a 1992 740 non turbo wagon with 104k the cars heat level on the dash has always been at about the middle never going past the middle, however yesterday when driving the car after about 30 minute i...
most of the cars made for Europe are equipped with a( thermostat ) but don`t confuse it with air conditioner thermostat or thing is working like valve that stops water circulating in cold starts so the water will only circulate around the engine block not through the radiator and of coarse it helps heat up your car`s engine faster but the problem comes when that valve got old (by the way most of those valves working as a wax capsule when the water heats to some amount the wax molten so it opens the way for water to circulate through the radiator ) what happens is simply the wax looses some of its function and molten in higher temp . so it block the water again until it heats up to molt the wax my advice : get off that part and just don`t replace it if you found it pricey for you your car still working but will needs more time to warm up i hope i was useful for u sir .
May 24, 2011 | 1992 Volvo 740
Emachine D2880 worked fine yesterday will not power on today
when you push the power button, fan or blower on power supply spinning or not? of not. your problem is power supply, nut if yes... did you hear any beeping sounds?
Jun 19, 2010 | E-Machines eMachines Desktop PC
Has no manual
May 14, 2010 | Health & Beauty
Has no manual
Mar 24, 2010 | Health & Beauty
Can Homedics Therapist Select? Shiatsu Pillow with Heat be used under 220 V power? Thanks
If it is set up for 110 volts, you should not use it on 220. Most likely you will burn the motor out in a matter of minutes.
Jan 24, 2010 | Homedics PA-4H Programmable Percussion...
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore he3 not heating
REMOVE 2 SCREWS ON BOTTOM OF PANEL,, REMOVE LINT SCREEN , NOW REMOVE BLACK METAL HOUING ,,,DISCONNCT POWER BEHIND METAL HOUSING THERMAL FUSE IS RIGHT THERE REPL ,NOW SHOULD HEAT UP ,,,2 RED WIRES CONNECT TO IT
Nov 23, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Health & Beauty Logo
67 people viewed this question
Top Homedics Health & Beauty Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
