Phaser 6510 will not print when has 024-747 error code
SOURCE: PHASER 8200N ERROR CODE 15,004.45:7829
There are 2,,,, 150 watt halogen lamps in that machine that heat the drum. One or both have blown. How to be sure is, turn the lights off in the room of office the machine is in, turn the machine on, and look into the right side fan slots. After a minute or 2 you should see a glow inside the machine. ( You won't) those lamps are bad. Xerox will want to sell you a new drum heater for over $200,You can go anywhere that sells halogen lamps. Lowes, Home Depot or just about any place that carries lamps will have them. They are less than $15. I recommend , if you can find , the Sylvania lamps that are rated for 130 volts and are vibration protected.
If you want to try and replace them. let me know I will send you written instructions. Should take an hour or so to replace.
SOURCE: Error code in Phaser 8550 window. ?:07,010.43:1362
The exact explanation per xerox is " The Printhead is stuck in the tilted position, and is not able to tile forward to the print position, due to problems.
This is usually caused by broken printhead restraints, of the machine got shut off in the middle of warming up, and the printhead is stuck to the cap wipe assembly.
Regardless the machines covers will have to be taken off to go any further.
SOURCE: Xerox Phaser 8860 error code 04, 025,.46:0?
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
