Question about Hotpoint Dryers
Where and how do I do the priming the water system for hotpoint dryer TCM 580
Posted by paul hogg on
2 Related Answers
W.L.
  • 2509 Answers
SOURCE: hi i have a hotpoint
You need to clean all the fluff out of the dryer, the heat exchanger gets fluffed up, the fan gets fluffed up.I am assuming that the dryer is getting hot?
Posted on Mar 05, 2011
Tom Chichester
  • 55379 Answers
SOURCE: hotpoint Aquarius condenser dryer, TCM 580p. Where can I purchase a pump microswitch?
A local appliance parts supplier might be able to help. You also can go to www.repairclinic.com and enter Hotpoint TCM580P to see a list of available parts.
Posted on Dec 16, 2015
Hotpoint Aquarius condenser dryer, TCM 580p. Where can I purchase a pump microswitch?
Dec 16, 2015 | Dryers
How do I change belt on TCM 580
Make and complete model #?
Oct 16, 2014 | Dryers
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
My hotpoint condensed dryer is steaming up my windows and I don't know why as I thought that was the point of the condenser. It's model number is Tcm 850, anyone got any suggestions or can help, thanx
Hello Scot, just make sure the fluff filter is clean and the exit tube for the air is clean they should just slide out fluff filter and pull off the fluff and the air exit tube normally get quite dirty with fluff and debris. So take that out and take it outside and wash it through with a hose from both ends. The water tray should also be emptied regularly but the panel will tell you when that is full.
Hope that helps
Steve
Oct 12, 2013 | Hotpoint Dryers
Hotpoint tcm 570 warms up but doesn't spin
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 14, 2011 | Dryers
Hi i have a hotpoint tcm condenser dryer and dosnt seem to dry my clothes anymore?
Mar 05, 2011 | Dryers
I have hotpoint consdenser dryer model ctd00p - not drying clothe
if the water tank is empty you probably need a new thermostats .
Feb 11, 2010 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
No Water
One other thing some of the water in in a coils so if the dryer is new it will take some time to prime and fil the tank dont worry it wont heat when the tank is full and will tell you to empty the tank when it needs it ..hope this helps
Jan 26, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
63 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
