Question about Furniture
WIne Enthusiast wine cooler flashing error code EL
Free Standing, Classic Black Wine Refridgerator 269 01 66 03
Posted by BJ McCauley on
Jason Hanks
    New Friend:
  • 17 Answers
It's a temperature sensor problem. I'm familiar with this model and the factory where it's made. This model has an issue with the temperature sensor going bad prematurely. Call Wine Enthusiast and let them know the problem. They will likely send someone out to fix it.
Posted on May 02, 2019
Taking Care
    Master:
  • 385 Answers
It could be electrical issue you can find the same model here or newer model>>www.discountbargainprices.com
Posted on Feb 11, 2019
1 Related Answer
Sheldon Dedek
  • 912 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
What clearance do I need between the wine cooler and surrounding cabinets and counter top?
According to "Air-n-Water.com," the rule of thumb for non-front ventilating, free standing units is a 3" clearance all around. Hope this hel
Nov 06, 2014 | Dishwashers
How can I attach my wine rack to the wall?
Most of the wine racks designed for free standing although it is recommended to anchor them to the wall. In order to do so, you should drill through the rear spacer bars of your rack and attach it to the studs in your wall or you can simply use an "L" bracket.
Aug 13, 2012 | Furniture
What do I need to consider before buying a wine cooler?
There are many factors that need to be taken into consideration. Some of the more important include: type of cooling system (free-standing or built-in), bottle capacity and racking options.
Jul 31, 2012 | Furniture
I have a Koolspace AA6 Tuscany free standing unit. Sn 05314-11. Power went out cooling unit will not restart. I get the thermostat to read and fan to turn for a while then goes into high temp alarm mode.
It seems like this cooling unit (AA6, also Grand Cru 800) just doesn't last as per numerous postings that I found when I was trying to find a replacement unit. Best advise seems to be get a higher output unit that will fit application.
May 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Wine Refridgerator - Class Action Lawsuit
Franklin Industries (Franklin Chef) has filed for bankruptcy protection as of 9/11/09:
http://www.franklinchef.com/important.html
Looks like we are out of luck
Sep 09, 2009 | Franklin Industries FBC360D Beverage...
Where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Mar 31, 2009 | Magic Chef MCWC45A Wine Cooler
[email protected]
can you pull it out and see if the compressor is running,if it has a fan hold the fan with a rag to stop iy and put your hand on the comp. to see if it is running,if not i think you need a 3in1 start to get it going again,let me know what you find-mike
Nov 12, 2008 | Oster 12-Bottle Wine Cellar - Black
Frost is building in wine cooler
Check the door seals to make sure they are sealing good this can cause high humidity. The unit also seems to be getting to cold check with another thermometer
Sep 05, 2008 | Marvel (6SBARBSG) Wine Cooler
Furniture Logo
825 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
