Question about Samsung Audio Players & Recorders
I'm trying to use a Blackweb BWA17AV003 Bluetooth Audio Transmitter (with the included headphones) with a Samsung Series 5 5100 TV.
I have the RCA optical cord with adapters to get the optical output to work with the Bluetooth transmitter. When the transmitter and headphones are turned on, I get a message that says "Bluetooth mode" (I think, it's not the best voice emulation). Both blue lights are solid, so I believe it's pairing fine. I just can't get the TV's sound into the headphones. I turned them all the way up, but they just chirped at me. Setting the TV's audio setting to "External Speaker" did nothing.
Posted by Stephanie Reinheimer on
5 Related Answers
Anonymous
  • 119 Answers
SOURCE: audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
Posted on Nov 03, 2006
Anonymous
  • 279 Answers
SOURCE: Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Posted on Aug 31, 2007
Anonymous
SOURCE: audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Posted on Nov 10, 2007
Anonymous
SOURCE: hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one: http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
Posted on May 31, 2010
Azrael SRL
  • 11800 Answers
SOURCE: New Sony MDR-DS6500 wireless headphones.
Simple test to see if the unit is functional: get a cable like
http://www.amazon.com/3-5mm-Stereo-Male-Cable-ft/dp/B002T4OMG8
plug it in the headphones output from your pc or whatever device which you know it works since you are using it with other regular headphones (even a phone will do) and see if you hear something. If you don't then it's defective, if you hear then the problem is with your HT.
The biggest one is the fact that the only way in which this HT is capable of delivering sound to another unit is thru the wireless S-Air connection which the wireless module from the headphones doesn't support - it can connect strictly only to the module from its base which accepts only cabled connections, which your HT doesn't have..
To put it simply there is no way to connect this headphones to this HT. If you want to use those headphones you will need to get a real receiver and use this HT strictly as an BR player.
Posted on Sep 11, 2011
1helpful
How do I install my Bluetooth audio transmitter to my T V, so I can use the head set. I have mod # BWA17AV003
Attach the transmitter to the audio out on the back of the TV or your cable box It must have an audio out
3answers
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
2answers
Wireless headphone connection on Samsung UN40H6203AF
Are the headphones regular wireless (with a transmitter, sometimes called base or dock) or are they Bluetooth headphones ?
Bluetooth adapter for TV
User Fm transmitter instead of Bluetooth transmitter......i doubt bluetooth adapter will work on tv with headphones..
1helpful
4answers
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
1helpful
4answers
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
2answers
I have new RCA model VHP141 Headphones but will not work with my new Vizio TV. Where do I plug them in the TV?
Visio might not have a headphone jacks at all! Look around your set and, probably you won't find jack marked as headphone. You might need to use wireless headphones, what have an rca plugs and connect them to audio monitor out on your tv set.
Alex's TV Service,
Philadelphia, PA 215-806-5980.
1helpful
RCA wireless headphones
Hey, my rca whp141 is incredibly quiet. Go ahead and turn the volume up on the TV.
If that doesn't work make sure
  • The headphones and headset are on the same channel (like 1).
  • the transmitter is on and working (Power: GREEN LIGHT)
  • the headset is on and working (GREEN LIGHT)
  • the headset is receiving a signal (St: GREEN LIGHT).
Hope this helps.
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
