I have a Peakeep Digital Alarm Clock with 2 Alarms for Weekdays, Manual Snooze and Light, Battery Operated. I don't know how to change it from having 2 alarms on screen to just one.
Posted by Catherine Tubbesing on
Stephen Miller
  • 1,645 Answers
3 Related Answers
Anonymous
  • 239 Answers
SOURCE: CAN U CHANGE THE SNOOZE TIME ON THE ALARM CLOCK AND HOW?
you go to your alarm settings in there you will find the option that snooze time in there you will change the time for snooze
Posted on Jun 11, 2009
peyote612
  • 5 Answers
SOURCE: Problem with launcher Pro and alarm clock. No way
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Posted on Jul 14, 2011
deton8 von Splosion
  • 3339 Answers
SOURCE: I have a Loud Alarm battery-operated clock. I can't get the screen to light up, even though the snooze button says Snooze/Light. How do I get the light to turn on?
Replace that bulb.
Occam's razor
(or Ockham's razor) is a principle from philosophy.
Suppose there exist two explanations for an occurrence. In this case the simpler one is usually better. Another way of saying it is that the more assumptions you have to make, the more unlikely an explanation is. Occam's razor applies especially in the philosophy of science, but also more generally.
Then replace/rebuild the Clock-Radio's switch.
I'm just saying
Occam razor Simple English Wikipedia the free encyclopedia
Posted on Jan 07, 2016
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help
    support.google.com > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' Chron.com
    smallbusiness.chron.com > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    worldwide.bose.com/...setting...alarm/page.html
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
    support.lenovo.com/us/en/documents/ht101173
    Lenovo
Jan 30, 2016 | Home
Replace that bulb.
Occam's razor
I'm just saying
Jan 07, 2016 | Audio Players & Recorders
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
Need manual for iCraig CMB3228. Can not reset clock or alarms.
with the power off press and hold the vol+/alm1 until the hour is blinking then change, press the vol+/alm 1 again to change the mins. same thing for the alarm 2. make sure the PM light is lit up if it an afternoon alarm.
what I need to know is How to turn off the alarm completely?
Nov 24, 2012 | Craig iDual Alarm Clock, Digital PLL FM...
I need a manual on how to set the time and alarms on fm/am cd clock radio model # rp 5600a
To set the time, press Set (furthest left button in the line including the Snooze) repeatedly until the clock icon shows on the display. Then press the FWD or REV buttons (on either side of the Snooze button) until you reach the current time. Press and hold to advance the time more rapidly. Press Set to save the time.
To set the alarm, press Set until Wake 1 or Wake 2 is shown on the display. Then follow the same directions as changing the time. Press WK1 or WK2 on the front of the clock to select the type of alarm.
The manual for the RCA RP5600 is available on the product page: http://www.rcaaudiovideo.com/audio/clockradios/?sku=RP5600 . See the Support/Manuals tab. The direct link to the manual is http://audiovox2.info/docs/common/RP5600/RP5600_OM.pdf .
I hope this helps.
Oct 22, 2011 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Don't know how to set alarm(s) on a sunbeam digital LED alarm clock model #C38. Can you help??
It's very easy to do. First, make sure the 2 little slider switches on the far right hand side that turn the alarms on and off, are in the "down" off position.
On that clock, just to the right of the large snooze button there are 5 small square buttons. Time, Fast, Slow, Alarm set 1, Alarm set 2.
Depending on which alarm you want to set, hold down that button and simultaneously push either the "fast" or "slow" button to the left of it. The numbers will move forward fast or slow depending on which button you're pressing. Keep an eye on the upper left corner to determine when you've gone past 12 noon - as the indicator for PM will light up.
Keep holding down the 2 buttons until you get to the time you want. Then immediately release the fast/slow button. Your time is set. Do the same for alarm 2 if needed. When finished, flip up the switch for the alarm you want to activate, and you're good to go. Piece of cake! It took me a few minutes to figure it out; but after doing it one time...it's easy. Hope that helps.
I love this old Sunbeam clock. Only problem is the alarm is not very loud and there's no way to raise the volume - short of connecting wires to the speaker and using a powered speaker. Cheers!
Sep 24, 2011 | Audio Players & Recorders
Hi, i missed the operational manual of my LEXON LA-78 CUBE CLOCK RADIO and i cant make it work properly. If you have the manual, please send it to my mail account. Best Regards Sotiris
I have a scan in of the instructions for the LA78 - not very clear but adequate. If the problem is you don't know how to tun off the radio alarm set icon, hold down the Snooze/Light button 2 secs (blue display will light up)
Aug 16, 2011 | lexon iHome IH12BR Cube Clock Radio wiPod...
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Emerson Smartset alarm clock
Hi - You can download the manual from the link underlined in blue below:
CKS3528
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jun 25, 2008 | Emerson Smartset Clock Radio
276 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
