Question about Toys
Just got a Thunder Tumbler. Put batteries in, turned on remote and car. When I press a button on the remote, the car lights flash but won't move. Do I need to return this or is there an easy fix?
Posted by Daprima Inizio on
Stephen Miller
  • 1,645 Answers
Posted on Feb 10, 2019
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: wii remote not working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 03, 2009
Anonymous
  • 11 Answers
SOURCE: My grandchild got a Thunder Tumbler for
Make sure your remote is not cracked in tha back because it will not work & make sure tha batteries are put in all tha way
Posted on Dec 29, 2009
Anonymous
  • 11 Answers
SOURCE: our thunder tumbler only goes forward on back two
there is no problem that is tha way it is sopoesed to be
Tom Williams III
  • 74 Answers
SOURCE: remotes won't connect. put in new batteries,
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Posted on Jun 28, 2011
mjt32488
SOURCE: Bought a new RCA 37LA30RQ.
Im pretty sure all you need to do at this point is reprogram the remote. If you dont have the codes go to the RCA website. They normally loose the codes when the batteries die and you have to change them out and re-program it. hope this helps!
Posted on Sep 09, 2011
How do I fix the remote on the RC Thunder Tumbler RC Car to prevent the tire from spinning as soon as the remote control is turned on?
Use the throttle trim control to try and adjust this unwanted throttle application out. Refer to the user manual on how to trim the remote functions
Oct 17, 2016 | RC Thunder Tumbler Rc Car
My son got a thunder tumbler for Christmas but the car will not turn off, the light remains on. What is wrong?
Probably different frequency remote relative to car, same deal with my sons......car and remotes need to be on the same frequency....either 27 or 49
Dec 25, 2014 | RC Thunder Tumbler Rc Car
Two of the remote control cars we bought are broken
Sorry but these are very cheap and no parts are made for repair.
May 05, 2017 | RC Thunder Tumbler Rc Car
Thunder tumbler
My Thunder tumbler works perfectly every day, until now, one of the wheels won't seem to move I looked inside and I saw a Lego brick was in there. There's in opening in the car which is where the peice is. So when I try to make it move only one other wheel moves. HELP ME!!!!!
Dec 26, 2012 | RC Thunder Tumbler Rc Car
My son received a thunder tumbler remote control stunt truck yesterday, (5/15/11) and it is already broken. My younger son broke the truck where the attena connects, however, I glued that and the truck...
try contacting the company. if the car wheels are broke or dangeling you would need new wheels. if the wheels arent the problem it could b the turning starvos
Aug 26, 2017 | Cars & Co Rc Remote Control Thunder...
My car alarm will not work (disarm) with the remote. when I use the key to open the door the alarm goes off and car won't start. I've repleaced the remote battery, with no luck. The red light on remote...
Here's how you fix this:
- Open the remote, and take a piece of paper (something small, I used a crushed straw wrapper) and put it on top of the battery. It needs to make the remote somewhat difficult to close, but it needs to close.
- Make sure the red light flashes EVERY time you press unlock/lock. Your car might lock/unlock now. If it doesn't, move on.
- Get into the car somehow. Yes, the alarm might go off. Ignore it, put the key in the ignition and turn it to ACC. Then and hold both buttons for a few seconds. The light should continuously flash.
- Turn the key off, and wait for the alarm to stop. Then press unlock. If it works, congrats! No more issue! If not, you may need to take it to the dealer for service.
I just fixed my remotes this way. The contacts wear out, and the battery box literally fell off of one of the remotes. Forcing the battery box against the circuit board is the free way to fix it. Remotes aren't too cheap! Good luck!
Sep 02, 2010 | 2003 Hyundai Tiburon
My grandchild got a Thunder Tumbler for Christmas.......but after putting in brand new batteries......it doesn't work Suggestions on fixing it or just return it?
Dec 25, 2009 | RC Thunder Tumbler Rc Car
Toys Logo
999 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
