Question about Locks & Locksmithing
Probably not! Sounds like something was damaged besides the plug. Clicking could be a tooth on the gear was damaged and now slips. The way I repair or determine what's wrong with locks is to take them off and start by manually operating the strike and then check / test the rest of the lock as I assemble it back to the door. If the gear is damaged, you should be able to see that once the lock is disassembled. Cross your fingers you find some debris in the lock and thats all....
Posted on Mar 12, 2019
I think your locksmith did something wrong. I had a similar problem about 3 years ago. There is no need in expensive operations or something. Just find a good locksmith (I was in Dublin and called these guys:https://www.locksmiths365.ie/ , find something similar) and ordered a new smart lock. That will cost you something like £50. Yeah, some guys here propose "cheaper" options, but, you know, cheap isn't always good. These guys can be trusted. They do their job real quick and fine. 3 years passed and I didn't have any problems with my lock.
Posted on Feb 07, 2020
SOURCE: 2000 dodge durango locks
This is a common problem on Dodge trucks. The noise is the sound of a small plastic gear that is stripped. The only solution is to replace the lock actuator.
Posted on May 31, 2009
SOURCE: Keys locked in car
buy slim jim, but be careful of electrical components , could be cheaper to have locksmith in the long run
Posted on Sep 13, 2009
SOURCE: I have a 2005 Spectra that I am having door lock
the lock actuator is going out. worse case scenario is you will have to lock it manually or replace the lock actuator inside the door panel. it may still be under warranty. call them and have the vin ready and they can look in their data base. if they prove to be unhelpful, please feel free to e-mail me and i will call. [email protected]
Posted on Nov 09, 2009
Testimonial: "Very helpful, very responsive!!"
SOURCE: battery dead and key is locked in truck 05
OK. Here goes; look at the ground wire on any utility pole. Go to Home Depot, Lowe's or the like and purchase a 4 foot peice of wire like the ground wire (steel not copper). Bend one end 90 degrees at about 6 inches of length. Then bend a slow curve in the entire length of the wire. Purchase 2 rubber door stops. Grasp the top right edge of your car door and gently pull outward. Insert a door stop. Place the other door stop at the top of the door and lightly hit it with the heel of your hand. What you are doing is opening the door JUST ENOUGH to insert the wire without damaging the weather stripping. Now use the wire to either pull the door handle or pull the lock to the open position.
Posted on Jan 18, 2010
SOURCE: Smart car radio code lost. radio locked up due to
Go To Your local smart dealer and it will cost you £15 for them to get it from the manufacture of the radio. Some the will have on there data base and cost £0
Posted on Jun 18, 2010
May 09, 2016 | Jeep Cars & Trucks
Nov 02, 2017 | Cars & Trucks
May 19, 2017 | Cars & Trucks
Aug 05, 2011 | 1998 Isuzu Trooper
Mar 23, 2011 | 2008 Ford Taurus X
Dec 13, 2009 | Kwikset Locks & Locksmithing
Sep 04, 2009 | Weiser Lock Powerbolt 1000 Lock
May 21, 2009 | Kwikset Professional Door Lock...
218 people viewed this question
