Make sure the filer arm is down and calling for ice and listen to see if the valve that allows water to enter the icemaker is making a noise. You may be familiar with that sound. If you don't hear it. the valve may need to be replaced. That is usually the culprit. Sometimes those older fridge valves are no longer available. You don't always have to have one that fits the same bracket. It just needs to functionally work as a valve and fit the tubes.
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
I just used the hair dryer and it worked the water is flowing again out of the dispenser
SOURCE: water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
SOURCE: GE Monogram fridge is not dispensing water. Ice
Check your QuickChill damper in the feature pan. If it fails/hangs in the open position, you get excess Freezer air in the pan and in the vicinity of your water tank, which can freeze it solid
SOURCE: Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
