Question about Maytag Washing Machines
Spins way to fast no matter which spin speed it is on-bearings?
It’s designed to spin fast on spin cycle but should be some speed difference if there are selections for different speeds. Control board problem most likely
Posted on Feb 09, 2019
SOURCE: Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Posted on Jan 15, 2008
SOURCE: washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Posted on Apr 29, 2008
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
SOURCE: F 50 fault code and will not spin
f 50 is a control issue needs to be replaced 3 screws in back of control panel pull top forward control is on the right part #w10189966 its about $160 to $190 easy to change
Posted on Mar 10, 2009
SOURCE: turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Posted on Jul 06, 2009
