SOURCE: have spark,no fire,sprayed starter fluid into throtle body but does not start
Turn key forward listen for the fuel pump to pressurize if you don't here anything then your fuel pump needs replaced and it's in the tank.
SOURCE: Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
SOURCE: wont crank unless u spray starter fluid in
Check The Fuel Filter And Your Fuel Pump Its The Problem %99 Of The Time.
Sincerely,
Michael Scott
SOURCE: Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
SOURCE: how to clean boat carburetor
Carburetors are tricky, They have to be completely dismantled, soaked in carb cleaner, make sure all the gunk is off, every jet clean and clear, If you can't get a wire through it, you won't get gas through it, make sure you can blow through it, Get some guitar strings, .009 is about the smallest guitar string you will find, you can buy them separately at the music store if you don't have one. Change the filter in the line, when the carbs go back on, the adj all have to be the same, not one wide open and 2 idleing, Float level is also important, they don't sell complete kits anymore, you have to buy the parts individually, gaskets , etc, good luck.
