Question about Cycling
How do I adjust the nut on the pedal of DXC 5000 DUAL ACTION CYCLE to allow the pedal to move freely on the bolt that srews into the long arm of the bicycle pedal?
Posted by Douglas Edward... on
5 Related Answers
Michial Gueffroy
  • 1140 Answers
SOURCE: bike pedal arm keeps falling off as i pedal.
You need a new crank arm. If you ride with the nut loosened what happens is the square part of the bottom bracket shaft wears the hole out in the aluminum crank and it no longer fits snugly no matter how much you tighten it down.
Posted on Jul 11, 2009
0RazR0
Mohamad Ali Kazi
  • 100 Answers
SOURCE: logitech dual action game pad not working on Combat arms
Yes guys, I spent 5 hours on this. You know what the problem is? Its the HackShield Pro software this game uses. Everytime you start the game you will see HackShield Pro starting up. This shild treats a gamepad as a "hacking tool". Every online game these days is protected with such shields; another example is PunkBuster. To by pass this shiled is a pain in the ****. It needs scripting and thats not legal anyways.
The only way around this is to contact HackShield and ask them to add your profiler software to their whitelist. Read the last answer in this topic for more info:
http://forums.logitech.com/logitech/board/message?board.id=pcgaming&thread.id=1754
Posted on Jul 24, 2009
Anonymous
SOURCE: Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Dish washer does not drain. Checked for food being stuck anywhere. removed wash arm and plastic housing and checked for any type of blockage. Dishwasher hardly used.
Posted on Nov 17, 2009
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: Driver side wiper blade not moving when you turn
the wiper transmission which is also know as a linkage is stripped out
Posted on Feb 27, 2010
Ted Schore
  • 7353 Answers
SOURCE: The shifting lever moves freely
just buy a new arm.
Posted on Nov 12, 2010
I need and owner's manual for a dual action cycle model number DXC 5000
Geta clymer shopbook or similar online..whats the issue
Jul 25, 2018 | Garden
Front pedals
Yes, you got the bolts too tight on the axle shaft. You have to "sets" of nuts, the inner and the outer. The inner nuts on the shaft, which go inside the fork, should be adjusted so the wheel is rolling freely, with just a tiny "slop". Now, you will need to figure out a way to tighten the outer nuts to hold the wheel on the fork without turning or moving the inner nuts! Some bicycle shops use specially thin wrenches.
Be blessed.
Aug 08, 2013 | Schwinn 12" Roadster Tricycle
Brake light does not work after replacing bulb
It's usually the brake pedal is sticking or you might just need to adjust the pin when you apply your brakes it makes those lights stays on. sometimes you can spray a wd-40 and it'll go away.. this pin is located on top of the brake pedal when you look underneath the steering wheel column or panel....hoped i helped you on this one...
The brake light switch may be either stuck or broken.
Get down in the driver's footwell, and follow the brake pedal arm up under the dash. Look for the switch (see link for a picture), see if the moving arm on it moves freely as the pedal is depressed. If not, try spraying some lube on it (WD-40 or the like) and working it to get it to move freely.
If the arm won't move freely, or the lights don't turn on even when you move the arm, the switch should be removed and replaced.
Buy custom car parts.
Jun 02, 2012 | 2007 Toyota Tacoma
I can't get my brake lights to come on. I was told to change the stoplight switch. I don't know where its located or how to replace it.
It may not need to be replaced, just adjusted. The switch is located under the driver's dash. You'll have to get down low with a flashlight and follow the brake pedal arm up until you see the switch. As you look, gently press the brake pedal and see how the pedal arm pushes against the switch. The switch has a nut which you can loosen, allowing you to move the switch closer to the pedal or further away. The nut then must be tightened securely so that the switch will stay at the proper adjustment. The switch has to be close enough to the pedal arm so that when the brake is pressed, the switch plunger makes contact. If it looks this is already happening, replace the switch and adjust the new switch as above.
Jan 27, 2011 | 1992 Toyota 4Runner
Where is the belt tightening adjustment located. I have tried turning the nut under the alternator but nothing is moving. The belts and idler were recently replaced, but they are getting looser and looser.
Richard, please exercise caution when working on belts on your engine. If you haven't already I would suggest disconnecting the negative battery terminal to ensure nothing will move when your hands are in the belt area. Your question did not indicate what type of Toyota or year it is. I have a two type of belt answer:
On my 87 Toyota truck, the "V" belt idler for my AC pump was adjusted by loosening the nut in the center of the pulley wheel, then adjusting a bolt behind the idle pulley in or out as needed. Turing the bolt moves the pulley in or out depending on what way you turn it. When the belt is tight, you then lock the pulley in place by tightening the bolt in the center of the pulley. My alternator was the belt tensioner for the second belt. The top nut would allow the alternator to move, but you also had to loosen the lower bolt and nut under the alternator to allow it to pivot on that bolt. The top nut was tightened when the desire belt tension was achieved. The lower bolt is tightened back as well. Over tightening the belt can put extra wear on the alternator and water pump bearings, so use caution.
If your vehicle is newer, the belt might be flat or a serpentine belt type. These types of belts are kept tight by a spring load from the idler pulley. The spring is inside the round housing part of the idler arm. That end is usually attached to the engine. The pulley is on the swing part of the arm and is used to apply tension to the belt to keep in on all the other pulleys. In the casting, you will see a square hole for your 3/8" socket wrench to fit into. This allows you use your wrench to release the tension from the belt. The spring and movement of the arm applies the required tension to the belt and does not need to be adjusted, but just inspected every so often to make sure they still move. In your vehicle engine area, you might have a small diagram showing the route the belt takes through your accessories on the engine. When the pulley arms get old, they can stick and not apply the proper tension to the belt. The belt does stretch when it first is used and when it gets older. Your new belt circumference might also be too big now and the pulley arm might be at its limit of travel. I would suggest taking it back to who did the work to have them correct this. You can check the tension by pressing down on the belt between two pulleys and note the movement of the idler pulley arm. The pulley arm should move back when your release hand pressure to the belt.
I hope this helps. Please leave feed back if this was useful to you. Thank you.
Jan 01, 2011 | Toyota Land Cruiser Cars & Trucks
I've just replaced the brake light switch on my Chevrolet S-10 pick-up. The brake lights stay on as if I have my foot on the brakes. How do I adjust the switch? Calvin
  • 1 Remove the negative terminal on the battery using a wrench. Look up under the dash and follow the brake pedal arm up to the switch. Pinch the tabs and pull the electrical plug out of the brake light switch.
  • 2 Remove the nut closest to the brake pedal arm using a socket. This allows the switch to be removed from the bracket.
  • 3 Install the new switch by adjusting the rear nut, closest to the electrical plug, back toward the plug until it is a few threads away from the plug. Remove the front nut closest to the button. Push the switch into the bracket with the button facing the brake pedal arm. Install the nut on the button side of the switch.
  • 4 Push the switch in until it contacts the arm and depresses the button. At this point, use your fingers to turn the front nut back until it contacts the bracket, keeping the switch from pushing back out of the bracket. Adjust the nut as necessary to assure the button is depressed against the brake pedal arm without moving the arm. Run the rear nut up to the bracket to lock the switch in place. Tighten the rear nut with a wrench.
  • 5 Install the electrical plug on the brake light switch. Install the negative terminal on the battery, and tighten with a wrench
  • Aug 30, 2010 | 1994 Chevrolet S-10
    1995 ford ranger with new cluch and slave. still has pedle play for the first half of the pedle throw
    IF YOU ARE SURE THE MASTER CYL IS GOOD ,WHICH I WOULD HAVE DOUBTS ABOUT ,THEN YOU NEED TO ADJUST THEPUSH ROD AT THE TOP OF THE CLUCH PEDAL "YOUDOIT "
    Oct 23, 2009 | 1995 Ford Ranger Supercab
    Dual gate Hurst shifter adjustment
    Hello! Here is what I was able to track down:
    Hurst Dual Gate Shifter Assembly Parts Breakdown:
    Removing & Replacing The Hurst Dual/Gate
    1. Disconnect car battery.
    2. Remove Knob. Remove four Phillips head screws that hold escutcheon plate down to console.
    NOTE: SHORT SCREW IS USED IN REAR RIGHT - HAND HOLE. Remove escutcheon plate and console from floor tunnel.
    3. Lift selector indicator lamp housing out of shifter and pull bulb socket out of lamp housing. Disconnect wire connectors from combination Back - up light / Neutral safety switch.
    4. Remove two 1/4 - 20 x 1/2 hex-head cap screws that fasten Dual / Gate shifter to rear mounting bracket. Remove 1/4 - 20 x 1/2 hex - head cap screw that holds cable bracket to shifter frame. Remove two #10 - 32 x 3/8 slotted head cap screws that fasten Dual / Gate shifter to front bracket. Free shifter from cable by removing cotter pin and washer.
    5. Remove combination Neutral - safety / and Back - up light switch. Install switch on Replacement unit.
    6. Install replacement shifter unit in reverse order of removal of original unit.
    7. ADJUST CABLE: SEE FIGURE 1 (Below)
    Loosen nut that fastens cable pin to transmission control arm. Loosen nut enough to allow pin to slide in the slot in the arm. Turn the arm to NEUTRAL position. Move the stick to NEUTRAL. Tighten the adjusting nut. Test movement of stick and check to be sure that stick positions agree with transmission control operation.
    8. SEE FIGURE 2 (Below)
    Connect car battery. Apply hand brake. Move stick to NEUTR AL position. Press foot on brake pedal. Start engine. If starter fails to operate, Neutral Safety switch must be adjusted. Adjustment is made with a long-bladed Phillips screwdriver through the "Street" gate. This screw is directly in front of the st ick. Turn the screw about 1/2 turn past the point where starter operates. (STICK MUST REMAIN IN "NEUTRAL" WHILE ADJUSTMENT IS MADE). Starter should operate ONLY when stick is in PARK or NEUTRAL position.
    Hope this helps and thanks for using FixYa!
    Oct 22, 2009 | Pontiac GTO Cars & Trucks
    Adjusting Padking Brake with 4 wheel disc brakes.
    Hope this helps. This is out of the factory manual. Let me know if this works for you.
    PARKING BRAKE NOTE: Tensioner adjustment is only necessary when the tensioner, or a cable has been replaced or disconnected for service. When adjustment is necessary, perform adjustment only as described in the following procedure. This is necessary to avoid faulty park brake operation.
    1. Raise vehicle.
    2. Fully back off cable tensioner adjusting nut at equalizer to create slack in cables.
    3. Remove rear wheel/tire assemblies. Remove brake calipers and rotors.
    4. Verify park brakes are in good condition and operating properly.
    5. Verify park brake cables operate freely and are not binding, or seized.
    6. Check park brake shoe adjustment.
    7. Reinstall rotors and make sure rotors turn freely.
    8. Reinstall brake calipers. Tighten guide pin bolts to 41 n·m (30 ft.lbs.)
    9. Reinstall wheel/tire assemblies after brake shoe adjustment is complete.
    10. Lower vehicle enough for access to park brake foot pedal. Fully apply park brakes
    NOTE: Leave park brakes applied until adjustment is complete.
    1. Raise vehicle again.
    2. Mark tensioner rod 6.35 mm (1/4 in.) from edge of tensioner bracket Adjustment Mark On Cable Tensioner Rod
    3. Tighten adjusting nut at equalizer until mark on tensioner rod moves into alignment with tensioner bracket
    CAUTION: Do not loosen, or tighten the tensioner adjusting nut for any reason after completing adjustment.
    1. Lower vehicle until rear wheels are 15-20 cm (6-8 in.) off shop floor.
    2. Release park brake foot pedal and verify that rear wheels rotate freely without drag. Verify pedal returns to fully released position.
    3. Lower the vehicle
    Mar 09, 2009 | 1999 Chrysler 300M
    Cycling Logo
    482 people viewed this question
    Top Cycling Experts
    Marvin
    Marvin
    Andrew Taylor
    Andrew Taylor
    Bill Boyd
    Are you a Cycling Expert? Answer questions, earn points and help others
