My camera while pressing the registration button shows me an error message in the data What is the problem and how to fix it
SOURCE: error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
SOURCE: error message
hi i have the sony DCR-PC53E camcorder with the error code E:61:10 does anyone have any suggestions on how to fix this problem any help will be more than appreciated
SOURCE: Camera Sony DCR-TRV145E and software compatibility with Windows 7
j'ai un problème de demarrage de caméra. affiche toujours "system infolithium"
SOURCE: handycam utility will not work
Took me a lot of cursing, and it's very simple. On your camera's screen there are 2 options saying "USB Connect". Only when you look really closely do you see that the 1st one is for the hard disk and the second is for a memory card. I expect you are using the wrong one..I was!
