You can download the complete instruction manual for those scales for free at this link...
https://www.manualslib.com/manual/966386/Weight-Watchers-Ww67t.html
SOURCE: err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
SOURCE: the wii fit weighed in pounds but the fit plus
Multiple your Kilogram total by 2.2 to get the pound equivalent.
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
SOURCE: EKS bathroom scales Model:8901BM
Turn the scales over so that you're looking at the underside. You will see a 2-way switch that says "Kg" on one side and "St" on the other... Choose either kilograms or stones.
