Question about NTI Computers & Internet
SOURCE: using drop-down form field in a word 2007 template
You need to protect the form (Protect Document, Editing Restrictions (Filling in Forms) then Start Enforcing Protection, the drop down menu will then work.
Posted on Sep 29, 2008
SOURCE: word 2007 form fields
you have need for assistance at your home only!!
Posted on Aug 16, 2009
SOURCE: VGA input not working... won't work with a
You have to make sure that you set the computer to send out the VGA signal that does not exceed the TV resolution, otherwise you will get 'unsupported signal' error. You need to find out what the resoluttion the TV can do in PC mode.
Posted on Nov 10, 2009
SOURCE: Hello, Problem within setup utility.
the blocking thing is per day. so if you want to block or set rule like for a example monday of 23:30PM to tuesday of 6AM, you should have 2 rules, 1 is for monday which is 23:30- 24:00 and tuesday which is 0:00-6:00. that should work
Posted on Mar 27, 2011
