Washing Machines Logo
Question about Maytag Washing Machines
How many pounds of laundry does a Maytag A210 washer hold? I can't find it anywhere.
Posted by Priscilla Pinkowski on
My Maytag comercial top laser washer has LCSU displaying on the screen? What does it mean
https://producthelp.maytag.com/Laundry/Washers/Product_Info/Washer_Product_Assistance/F8_E1_or_LF_or_LO_FL_Error_Code_in_Display
Hello, what is the capacity of Kenmore washer 110.28803890 in kilograms? Thanks
As a rule of thumb, 12 pounds of laundry is appropriate for a standard capacity top load washer, 15-18 pounds for a front-load washer, and 20-22 pounds for an extra large capacity front load washer. 1 lb.is .4536 kg so 15*.4536 is 6. kg. 18*.4536 is 8.17 kg.
How do you manually unlock the door on Maytag Maxima front load washer?
Maybe look on Maytag website?
http://producthelp.maytag.com/Laundry/Washers/Washer_Product_Assistance/How_to_open_the_door_of_your_Front-load_washer_(when_it_will_not_open)
What is the tub size in cubic feet for maytag washing machine model no. a112
Why do you care??
Seriously...these machines are rated at 18 or 20 pounds but in reality it depends on the type of fabric and the size of the fabric. Think about it a moment.
Small items, say socks can be loaded well over the supposed limit but large heavy items may only wash well at half the rated load, the laundry has to have the ability to slide through the water in the tub. In spite of what most people believe, the laundry is not supposed to swish around going left-right, left-right but is drawn across the surface of the water, pulled down in the center of the wash basket and there the water currents are forced through the fabric, causing much less wear on the fabric and better cleaning results. Overloading the wash basket is The Major Cause of poor laundry results!
Tub capacity of maytag performa
It holds 3.9 cu feet. According to Maytag "This 3.9 cu. ft. capacity high-efficiency washer also features the MaxExtractâ„¢ option, which spins clothes at up to 1,300 RPM and means less time doing laundry. You get all that and still use 79 percent less water and 76 percent less energy". A cubic foot is the volume of a cube whose sides are all 1 foot long.
Maytag Auto Load-Sensing Washer does not fill with enough water to wash the clothes. How do I get around this?
Did you ever get an answer - all I see are ads :-(
We have the same problem. Not enough water to rinse - even with extra rinse selected. Even our laundry comes out the color of the laundry detergent. I'm sure this is a result of government regulations to reduce water usage. We'll contact Maytag tomorrow.
My maytag washer is giving an F H reading. I
http://laundry.manualsonline.com/manuals/mfg/maytag/mah7500.html
If the manual on this site doesn't help, you may want to try maytag.com for a manual.
as for the F H reading---you got me
Open Questions:
Top Maytag Washing Machines Experts
Steve
nu267
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
