Question about Tecnik Kitchen Ranges
A bulb blew in my tecnik cooker hood and neuith lights or fan will work is there a fuse that iu need to change
Posted by Betty Russell on
1 Related Answer
Anonymous
SOURCE: a bulb blew in my tecnik cooker hood and neither
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Posted on Dec 20, 2010
8helpful
A bulb blew in my tecnik cooker hood and neither the lights of the fan will work? is there a fuse somewhere that I need to change?
Hope this helps.
The lights and the fan in our Tecnik electric range cooker hood have stopped working. I am not certain of the product number. It was bought 5 years ago and is stainless steeI. I suspect a blown fuse but...
Hello Jack728,
I never have found a fuse IN a cooker hood as long as I repair them.
My first impression would be a faulty connection to the grid, as both functions of the hood do not work.
I hope this helps, Kind regards, Dik
Bulb blew on cooker hood and I replaced both. Light still won't work and neither will fan - both working fine until bulb blew.
hello. I can assist you. begin by going to the electrical panel for your home. You will be looking for the circuit breaker or fuse that controls this hood. Chances are the actual problem is that the fuse blew, or the circuit breaker kicked off. To reset, replace the fuse with a new one of the same amperage, or turn the breaker on and then off and then back on again.
3helpful
Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
2answers
Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Cooker Hood problem
check the printed circuit board behind the switches - maybe when bulb blew it took out some of the track. usually repairable by soldering in a link over the damaged track. have you checked the fuse as well?
4helpful
3answers
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
5helpful
3answers
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
3helpful
Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Kitchen Ranges Logo
Top Tecnik Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Paul Carew
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
