Question about Kitchen Appliances - Others
SOURCE: kenmore 90 series gas dryer door will not stay closed
try adjusting the door
Posted on Mar 24, 2008
SOURCE: freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Posted on Jan 18, 2009
SOURCE: sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door...
If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Posted on Feb 11, 2009
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
