SOURCE: to set the clock on a jensen cd 2010x cd in car player
1. Press DISP for approx. 3 seconds until you see the clock flashing. 2. Use the up and down to change the values and the right and left (<< >>) to change from hours to minutes. Then hit the Disp to exit.
SOURCE: set the clock on a clarion cd player?
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
Note:
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
SOURCE: How do I set the clock on a vc cd player
The clock setting illustration & instructions are found on Page 8 of the JVC KD-G720 manual:
http://resources.jvc.com/Resources/00/00/93/GET0354-001A.pdf
Again, check out Page 8 of that manual, upper left corner of the page... that should get you headed in the right direction.
I hope that helps.
SOURCE: i have an alpine cd player cde9845 in my car. how do i set the clock?
Follow the instructions on page 15 of the manual.
