Question about Jet Health & Beauty
HELL0. I NEED TO FIND OUT HOW MANY DEEP CYCLE BATTERIES THERE ARE IN A JET 1 DL 5.2i WHEELCHAIR. IF THERE IS MORE THAN 1 ARE THEY CONNECTED IN SERIES OR PARALLEL? THANK YOU. [email protected]
Posted by STEVEN BOWYER on
5 Related Answers
Anonymous
  • 741 Answers
SOURCE: my wifi not working
Go into the Device Manager. If you have a yellow! or Red X by the wireless adapter, then right-click on it and get new driver. This should take care or it.
Posted on Dec 22, 2008
protek480
Craig Butler
  • 1730 Answers
SOURCE: With all DC systems on no negative Ah readings
The shunt needs two (2) wires coming from it to your amp meter. If the meter reads backwards polarity, reverse the shunt leads.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
Anonymous
  • 120 Answers
SOURCE: Please describe how to hook
it depends on the charger output voltage verses the bulb voltage
Posted on Dec 24, 2010
lennieg2000
  • 692 Answers
SOURCE: Pride JET 3 Ultra power wheelchair. Problem:
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
Posted on Jun 10, 2011
Bill Boyd
  • 53816 Answers
SOURCE: 1997 Lund 1775 pro-v. has 2 deep cycle batteries, assume the both are for trolling motor. however, I can only get about 6 hours run time. are they separate or should be hooked in parallel?
to get extra run from batteries you need extra capacity which means that they have to be connected in parallel
Posted on May 31, 2017
Where are the Quantum 600 Fuses Located?
Ron,
With a gifted power wheelchair, the usual culprit is a pair of dead batteries usually size 22NF deep cycle batteries. The pediatric chair may have U-1 (35 amp hour batteries) There are fusible links connected to both batteries at the + terminal. There are additional fuses under the rear cover in booted holders in the belly area in the rear near the controller. These power take off harnesses are fused but probably do not relate to your primary dead battery problem. Remove the front cover of the base and pull out the battery tray. Remove the batteries, test, and replace.
The owner's manual can be found here. It also includes basic service. Hope this helps.
http://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_q600_series_om.pdf
Jul 22, 2016 | Quantum 6000 Power Chair - Used Electric...
What type of batteries does this model take?.jb.
you need 12v 33ah sealed deep cycle battery most likely it may need two batteries any thing above 33 amp hours would also be ok. A higher Ah the longer the batteries last. This information on the type of battery is from the user manual.
http://www.hardwarexpress.co.uk/rascal-388-mobility-scooter-battery-1949-p.asp
Any battery type store should be able to supply this to you .
Feb 10, 2015 | Electric Mobility Rascal Scooter...
How do I replace the batteries on 2005 pride mobility jet ultra 3?
Because liability issues and I do not know your mechanical ability or your limitations, this is only a recommendation.
1.remove seat
2. remove body
(be careful to the joy stick and its cable)
3. mark battery cable
4. take batteries to a wheelchair supply company
(wheelchair supply company will order correct batteries. DO NOT GET BATTERIES FOR CARS OR MOTORCYCLES. THEY WILL BLOW UP they MAKE explosive hydrogen gas)
5. reconnect cables to batteries
6. make sure there is a gap between the batteries for cooling
7. visually inspect that all cables are not going to get pinched,
8.covered up cables with the battery cable covers over
9. reassemble wheelchair making sure electrical cables are not rubbing or pinched. use zip ties to help, but not too tight because they can dig into cables.
I would take it to a wheelchair repair company because of fire hazard of doing this. Do this at your own risk
Jul 23, 2014 | Jet 3 Ultra Power Chair
Can i use lawnmower batteries in my jazzy wheelchair
If your lawnmower batteries are deep cycle AGM or Gel, have the rated aH & voltage, and fit in the battery well, then I say go for it.
Mar 17, 2013 | Health & Beauty
Can the hoveround batteries be charged with a trinkle charger?
simple answer is yes, However certain procedures need to be followed. take the batteries out of the chair or if you know what you're doing completely disconnect them. charge them (you have two 12v batteries in series) separately, keeping in mind they are either GEL cell or GLASS mat deep cycle type batteries. caution should be taken to not over charge them and unless the charger in designed for that type of battery specifically, not too many cycles and not for more than a few hours each time. they will dry out. just out of curiosity why not use the factory one that came with them.
Oct 01, 2012 | NRS Hoveround MPV 5 - Used Power...
Had the Pronto M91 invacare wheelchair in the Push more for a couple of years. Now My cancer is back and I need the wheelchair. I charged and nothing happen. All I see are a steady red light and a...
You definitely need new batteries. After that amount of time the batteries go bad and the plates inside become sulfated. They are only good as boat anchors now.
It is a easy do it your self repair. There are 2, Group 22 batteries in this model. You want to get deep cycle sealed lead acid, preferably AGM (advanced glass matt) group 22 batteries.
Flip the seating system back by releasing the lever under the front of the seat.Make sure you do not pinch the joystick wiring at the back when you do this.
Remove the black plastic cover.
The batteries will be secured by a strap which you should unbuckle.
Disconnect the plugs to the batteries and note how they are run, oriented and connected.
Pull out the batteries, one at a time, from the base.
Make the wiring connections to the battery , put the batteries back in the chair, plug everything in and you are set to go. Hope this helps.
Feb 13, 2011 | Invacare Supply Group Invacare Pronto M91...
Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
May 18, 2010 | Pride Jazzy Select 6 Indoor Power...
How do you do a load test on the batteries o f my jazzy 1115 power wheel chair?
You don't do load tests on deep-cycle batteries, unlike car batteries. Car batt's are measured in cold cranking amps, deep cycle are in amp-hours. The best way to test is to drive the chair (which loads it), and see how long it runs. It should take you a good five miles and still be in the green. If not, time for new batts.
Dec 26, 2009 | Electric Jazzy 1115 Power Wheelchair
How many batteries do I need for the chair
You will need two, sealed lead-acid, deep-cycle batteries. Go to a battery shop, not Sears or such and make sure you tell them they are for a power chair. Most chairs take U1 batteries, but larger chairs take group 22, and the biggest chairs use group 24. Mini-chairs vary, so take the batts in with you.
Dec 24, 2009 | Quickie Wheelchairs Quickie Aspire...
Only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
May 11, 2009 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
75 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
