Have you moved it? Sometimes a shelf will slide out of place and hang on door bin
Testimonial: "thank you for your quick response & ideas.. i'm new to this site (&also,new to a web site of Q&A). im a master plumber\gasfitter.. but this freezer door thing realy had me dumbfounded.. I removed the hinges & got a better look inside.. it was a combination of the shelf & door shelf.. it over froze & a huge ice block formed & basically froze the door to the walls of freezer??? so now I can use a hair dryer\heat gun 2 melt ice.. after 2 days I didn't think ice wood still be in there.. thanks again"
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
SOURCE: FREEZER NOT FREEZING AND FRIDGE NOT GETTING COLD
First check to see if your compressor is running at all. If your compressor is at room temperature you cold control is not supplying power to the compressor. Replace the control or locate the defrost timer and rotate the clutch head screw ( Normally black or Grey) and rotate it a small amount clock-wise. If the compressor then starts replace the defrost timer.
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
SOURCE: Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
SOURCE: I have a Kenmore Coldspot Model 106.59502992 that
Hi Danda,
About 98% of the time on a Whirlpool built Kenmore such as yours the problem with automatic defrosting is the "defrost timer". It's super easy to repair. You can get one from Sears, a local appliance parts retailer or just about anywhere online (just plug this part number---> 482493 <--- into a search engine and price shop)
Here's a diagram I made. It details the repair. Number 4 says "ADC", don't worry. There are two types of defrost timers one is an ADC and another is yours. They both follow the same repair procedure, OK?
Here's a full size diagram of your machine. You'll see that there is no difference other than the type of defrost timer.
NOTE---> UNPLUG YOUR FRIDGE BEFORE DOING THIS REPAIR!!! Otherwise, you'll look like this permanently...
There ya go, Danda! Remember to rate this solution as "FixYa" WillYa?
SG
