SOURCE: Manual For Alpine IVA-C800
A copy of the manual for the Alpine IVA-CV800 is available for download from the company's website. Click on the link to download. It's a 251 pages pdf file,
Good luck and kind regards.
SOURCE: I need a color code for a Sony Xplod CDX-GT23W.
Guessing that you don't still have the owners/install manual.
On the back of the head unit there should be a group of unused/unconnected wires (with any luck they will be marked), one or more might be an amp turn-on or power antenna lead, so I suggest (with the unit turned on) testing each wire with a DC voltage tester so as to identify and separate any leads supplying 12+ volts. the remaining group will consist of speaker leads. Trial and error testing will determine the proper L & R rear speaker leads.
Good luck
Aduz
SOURCE: im having trouble installing the sps-600c alpine
Hello lucal_s2000,
Well, actually those 600c's do have a crossover. It's encapsulated in the wiring you got with the components. Your head unit or amp speaker outputs connect directly to the woofers. The inline crossovers have a 12" wire on one end and a 22" wire on the other end. Connect the 22" side to the 2nd set of terminals on the woofers, and the 12" side to your tweeters, keeping all of the positives and negatives straight.
Here's an image of the connections.
Hope this helps.
SOURCE: speaker mounted amps in factory system not working
Check fot the ground to the amp and radio.............
