Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Canon MX860 printer error code B200. Can I fix this at home?
Posted by Jo Taylor on
5 Related Answers
Anonymous
  • 310 Answers
SOURCE: Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
Posted on Mar 03, 2008
Anonymous
  • 4 Answers
SOURCE: how to fix error b200 on my canon pixma mp620
Replace your printerhead will do the trick. Had the same issue with my MP980
Posted on May 07, 2010
Anonymous
  • 37 Answers
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
duane_wong
Duane Wong
  • 6826 Answers
SOURCE: Canon Printer Pixma MP540 with
Try to press down on the sponge to get it to work again. It may be a waste toner issue, which generally is repaired at an authorized service center for canon by contacting 1-800-OK CANON or logging on to canonusa.com.
Good luck on this.
Posted on Feb 12, 2011
Just got error code B200 and to unplug and cll support? Any ideas?
The B200 error seems to be a temperature sensor problem. It typically shows up when the print head has over heated in which case turning it off for 10 - 15 minutes will get you going again. Alternatively it often shows up when the printhead has delaminated and this is unrecoverable and requires either a new print head or a new printer (often the cheaper option)
Sep 04, 2016 | Canon Office Equipment & Supplies
How do I reset or fix an Error B200 Code on a Canon PIXMA MX860 Printer?
Dear
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
9. Plug the power back in and turn the printer on.
Thanks
Jan 15, 2015 | Canon PIXMA MX860 All-In-One InkJet...
Canon mx870 printer b200 error
http://forums.usa.canon.com/t5/Personal-Printers/Canon-MX860-repeats-B200-error-code-brought-it-back-to-store/td-p/489
Feb 19, 2014 | Computers & Internet
B200 error code displayed
http://www.youtube.com/watch?v=AyHaxjFg8aI
Jun 19, 2012 | Canon PIXMA MX860 All-In-One InkJet...
Canon MX860 printer is showing: "Error B200 Printer error has occured. Unplug the power cord and contact the service center." I have unplugged the printer and plugged it back in -- there is not...
It is my pleasure to guide you.
After looking at some information about the printer error and that the error tells you to "contact the service center" I have given you places to contact about this error. Some of the information that I have looked at about the error said that several things can cause the error. I suggest that you contact Cannon through the 'Email Assistance'.
Service & Support
Support Home ' http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx860#
Email Assistance ' http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx860#
Solutions List:
Contact Canon for B200 error (MX860)
Press ON switch and wait a few minutes before powering back on the device
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Jun 11, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Error message B200 on Canon Mx860
Hello and Welcome to FixYa!
According to Canon's documentation, Error B200 is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board, a physical hardware malfunction.
To solve it:
Turn off the machine, and unplug the power cord of the machine from the power supply. Again connect it and turn on.
If the problem is not resolved,
then best option is to take it back where you purchased it or contact Canon service center about the error code or
To get support by Canon on phone, then call at 1-800-OK-CANON (1-800-652-2666)
They will surely solve it.
I hope this solution helps you
For further assistance, I am here to help.
Thank you and Keep Visiting FixYa
May 02, 2011 | Canon PIXMA All-In-One Photo Printer with...
My Cannon MX860 has just posted a B200 error and won't work. Can you tell me what the solution is?
Buy a new printer because by the time you do all that, its cheeper to just throw it away. I have a PIXMA mX860 with the error b200. Only had it 3 years and took great care of it. P.S. Dont buy a Canon.
Dec 07, 2010 | Canon Office Equipment & Supplies
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
123 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
