Question about Vulcan Heating & Cooling
Hi, I have a Bonaire Vulcan Evap and the touch screen just went blank for no reason. I tries turning on and off t breaker and still nothing, any ideas?
Posted by George Kouts on
5 Related Answers
Anonymous
SOURCE: Blank screen
Try soft reseting your phone. If that doesnt work then try hard reseting.  To soft reset take the stylus pen and push in the little hole on the bottom of the phone. You should feel a little click and then your phone will restart. Wait until your phone  starts up again and if it still isnt working then do a hard reset.
 To hard reset, hold down the green send button and the red end call button at the same time and continue to hold them down as you then push your stylus pen into the hole on the bottom of the phone untill you feel the little click. Your phone should start to reset.  Be warned you will loose any information saved to the phones memory ie: phone numbers, pictures, personal settings. Anything saved to your memory card should be ok.
If your screen remains blank after trying both resets I would suggest taking it back to where you got it and and have them fix it or replace it.
Hope this is helpful.
Posted on Feb 22, 2008
Anonymous
  • 6 Answers
SOURCE: asus laptop - screen went blank and will not turn back on
I'm assuming your screen shows nothing at all, even the bios or boot screen as it turns on.
If you can hook it up to an external monitor then your video adapter is working. Try using the vga output on the laptop. If it doesn't show anything use you display select feature. I'm not sure what button it is on your laptop but on mine it is Fn+F8 (look for a button that shows a laptop and/or a rectangle).
If you can see it with an external monitor, you should try to uninstall and reinstall the video adapter. After you reboot the computer hopefully it will work.
However, if it still does not work, you will probably need to reseat the monitor cable. Do this by opening the screen panel. on the back is a flat cable tat plugs in to the LCD. This is usually covered by tape. Carefully remove the tape, unplug the cable and plug the cable back in. Don't forget to replace the tape!
I have fixed two computers in the last two weeks by reseating this cable.
Hope this helps and good luck!
Posted on Jan 11, 2009
pierre1811
Perry Putnam
  • 144 Answers
SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: touch pro screen blank
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Pls rate me FIXYA if it helps
Posted on Mar 14, 2009
Anonymous
SOURCE: Brother intellifax 770 No Power? LCD is blank
I have the same problem: no LCD. Determined that the outlet was fine, but the machine did not respond when unplugging/plugging it in. Support said I needed to take it in for repair. Unplugged it, unscrewed the bottom plate, and found a blown fuse on the circuit board connected to the power cord (needed to gently lift it from its cradle).
Posted on Aug 25, 2009
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
I have a similar problem
I just went into the Bonaire website and downloaded their FAQ on gas ducted heating from their support link. Their instructions are pretty easy to understand.
Sep 08, 2009 | Heating & Cooling
Will not turn on after a blackout
Turn off your breakers and then back on. There are fuses located in the a/c control panel. Check them. If you aren't getting any power still, a board may have been blown during the storm.
Jan 30, 2009 | Mastercool 67471 Evaporative Cooler Air...
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Touch pad on
It is more than likely the touch pad that is faulty. I have installed many bonaires, and the only thing to go wrong at that age is the touch pad, or the problem is in the control box in the airconditioner.
The touch pad comes off quite easily by placing something flat behind the pannel and leavering it off gently. The touchpad has two pieces, the front, which you see, and the mounting bracket. The bracket is almost as big as the front pannel, so you only have approx 2-3mm of plastic edge to lever, so be careful not to hook onto the mounting bracket as well.
Once you have removed the front, you can then unplug the lead coming from the touch pad (be sure to turn the control box off in the airconditioner before removing this wire, there is a switch on the side of the control box (yes, you have to get on the roof, sorry)). Take the touch pad to your local retailer that sells Bonaire units and see if that is the problem.
Jan 11, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
