Question about Xerox Office Equipment & Supplies
Erase lamp failure in xerox - Xerox Office Equipment & Supplies
Posted by RIZWAN on
Sameer Alkozay
    New Friend:
  • 12 Answers
You can test the erase LED while still installed in the machine. However, I recommend to first remove the Erase LED assembly. Then reassemble the drum in the machine. Next, cheat the top cover interlock switch, and place the machine into diagnostics, then run 09-66. This turns the eraser LED on. I usually hold the LED assembly and gently shake it as vibration will often uncover the weaknesses in the assembly. If a section turns off, flashes, or does not light at all, you know what to do. Otherwise, I leave the LED on until the timer function turns the assembly off.
Posted on Feb 06, 2019
Hallo, i have xerox phaser 3200 i want ask something why when i turn on the printer warming up progress can't finish (always warming up)
Srri but this is a fuser failure. The lamp has probably blown so it cannot generate any heat. best buy a new fuser unit. A lot of the machine has to come apart to fit it. You would be better taking it a shop for them to repair it.
srri
May 23, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Xerox XA3-17 makes noise, flashing, than nothing happens.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 08, 2010 | Xerox XA3-17B 17" LCD Monitor
My Xerox XG-91D LCD Monitor start, display briefly (about 1 or 2 secs) then goes back. any solution in this case? mention that i use with a dvi-i adaptor on a vga graphic card. thx
I would try VGA to VGA hook up first to narrow down the problem before start taking the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). See example of failed monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | Xerox XG-91D 19" LCD Monitor
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
Enter diagnostic mode
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
Xerox 5314 throwing a U8 code
It is the problem your copier heater unite conector is life out change it and solve your problem
Jun 30, 2009 | Office Equipment & Supplies
Phaser 8560 smudging problem
previous image on a copy are from two things
1-the blanking lamps that erase the image from the drum from the previous copy, and making it ready for the next image is bad
2- the fuser roller is bad and retaining the image on it.
Oct 08, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox
They have a scanning lamp and a fixing heating lamp. Xerox is funny when you need some free advice. They don't..... I work on every thing but Xerox, you may want to get in touch with a company called "Parts Drop" on the web. They have Helped me in the past before... Good Luck
Aug 22, 2008 | Canon CLC 1120 Color Copier
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
Xerox 432dc print engine error??
Check:
Hard disc Drive
Fuser
Laser
Nov 15, 2007 | Xerox 5665 Copier
Error code U8-6 on Xerox 5320 copier
dear sir please check the exposure lamp unit may be it is dusty so clean it or check exposure lamp circuit fuse etc....
Oct 07, 2007 | Office Equipment & Supplies
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
