SOURCE: Comfort Glow Vent-free Gas Heater CGN18B
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
SOURCE: range is 15 years old, used with propane. Now
Yes. For the oven, it is usually 3 full revolutions CCW. (easiest to count 12 one quarter turns with an open end wrench) Make sure to go through and reverse all LP conversion steps, including the regulator adjustment.
SOURCE: Do I leave gas value open when comfort glow vent
Just for tha sake of safety, close it!. You never know when something will happen. Usually right after you have questioned something and ignore it! Good luck...Lee
SOURCE: I bought a comfort glow vent-less space heater
According to the Comfort Glow Website, this is a Natural Gas unit. If you use propane you will need
a minumum 100# LP Cylinder and a pressure regulator. I have a Comfort Glow unit and went through the same process.
If you have it hooked up to a 30lb cylinder without a regulator I would think that if you purged the gas line
of air you should be able to light the pilot.
On a new unit you can expect to push the spark ignitor button at least a dozen times while holding
down the gas valve button.
Good Luck
I have a comfort glow gas heater that the pilot lights and when I start the heater it works for about 30 seconds then the whole thing shuts down.
