Video Cameras Logo
Question about Sanyo Video Cameras
Hello, I have a sanyo vm d66p camcorder and want to play it through a tv. What cables do I need ? thanks in advance
Posted by Caitlin Kiely on
Clyde Hanson
    Sergeant:
  • 221 Answers
You need the RF Adapter cables. I have seen items like that at thrift stores. The camera has that barrel connector
with 6? pins to connect it to the converter box that output to Channel 3-4. Keep checking ebay or craigslist.
https://www.manualslib.com/manual/894346/Sanyo-Vm-D66p.html?page=2#manual
https://www.ebay.com/itm/Sanyo-VM-D6P-8mm-Video-Camera-Bundle/163512488835?hash=item26121a9383:g:pLYAAOSwUMBb8MfJ:rk:1:pf:0
Posted on Feb 06, 2019
2 Related Answers
Anonymous
SOURCE: MY SANYO CAMERA MODEL 8MM VM-d66P SHOWS A WHITE
IF YOU CANT GET THIS FIXED CAN I BUY IT FROM YOU AS I NEED A 8MM CAMERA TO CONVERT MY TAPES TO DVD AS MY OLD 8MM CAMCORDER WONT PLAY.OR DOES ANYONE HAVE ONE I COULD BUY CHEAP OR BORROW...IN MELBOURNE AUSTRALIA...CHEERS JB
Posted on Feb 19, 2010
Anonymous
  • 17 Answers
SOURCE: I have old tapes from an old camcorder Sanyo
There are several ways of converting your tapes to a digital format.
1. By routing it through a DV camcorder with AV-input (these are increasingly rare though. (using firewire).
2. By using a device like this, which converts to DV. (also connects via firewire). http://www.dv247.com/invt/23453
3. By using a device which captures to MPEG2.
The cheapest way is option 3, but it requires a working camcorder. You should purchase a device similar to this: http://www.avforums.com/forums/attachments/camcorders-video-editing/85846d1216145397-camcorder-computer-easycap.jpg
If you don't have your camcorder anymore, or it isn't functioning, you should try to get a second-hand 8mm camcorder with firewire. This way you are able to directly convert your tapes to your pc.
If you can't find a firewire camcorder you could just settle with a good functioning 8mm camcorder but you will have to buy a capture device as mentioned above.
Posted on Jun 06, 2010
1helpful
Sanyo VM-D66P error: CASSETTE
There is a pulley that breaks inside but as these have been obsolete for over 20 years, I doubt it is repairable any more.
Fully working VM-D66p for £30 on amazon or fleabay.
When playing back cassettes on my Sanyo VM-D9P through the tv, the picture is blurred and jumpy and there's no audio. Can you suggest anything to help please?
As the camcorder is more than 30 years old it probably requires refurbishing and replacement of all electrolytic capacitors to get it to work.
Hello; i bought a sanyo crt tv(CM21MS22) yesterday,i watched on it yesterday it was fine, but today i turned it on and it is showing 3 black thin lines running from the bottom of the screen till the top...
under warranty? need more info. watching cable tv, or antenna, or using as computer monitor, model # check this website to get into the menu program and follow instructions tvservicemode.eleex.com
I have old tapes from an old camcorder Sanyo VM-D66P that I want to capture to my pc, how do I do this?
2helpful
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Tape wont eject
The deck may have went. Try bringing it to a local camera shop to get it out for you.
Camcorder hookup for tv?
I am successfully using my old Quasar VM-D51 camcorder as a WebCam and it works great. My computer has a TV Capture Card with an analog input (I am using the RCA plug on it). The camera has a output connection on the lower right side (just below the hand strap). You will need a mini plug to RCA adapter to make the transition. The software for the TV Capture Card does the rest. Radio Shack has all of the hardware you will need. Hope this helps. Good [email protected]
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
saphireb9
Level 1 Expert
john h
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
